C2G WS-G5483 1000Base-TX GBIC Transceiver
£57.37
Delivery:
Key features
  • GBIC Transceiver Module designed for use with Cisco network equipment
  • Functionally identical to Cisco WS-G5483
  • High speed 1-Gigabit connectivity
  • Transceiver type TX allows for connections up to 100m
  • RJ45 port deigned for use with a copper patch cable
Product codes
This Cisco WS-G5483 compatible GBIC transceiver provides 1000Base-TX throughput up to 100m over a copper connection using a RJ-45 connector. Our transceiver is guaranteed to be 100% compatible with the equivalent Cisco transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Cisco, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
C2G - GBIC transceiver module - GigE
GBIC transceiver module - RJ-45
Plug-in module
Cabling Type
1000Base-TX
Data Transfer Rate
1 Gbps
GigE
Max Transfer Distance
100 m
Cisco WS-G5483
3.05 cm x 6.6 cm x 1.02 cm
27.2 g
Cisco Catalyst 2912, 2924, 2948, 2950G-12, 2950G-24, 2950G-48, 2980, 3508, 3512, 3524, 3548, 3550-12, 3550-24, 3550-48, 4500, 4912; Supervisor Engine 1A 2GE, 2-MSFC2, 2-PFC2, II, II-Plus, IV, V, V-10
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G WS-G5483 1000Base-...
£57.37
