This Cisco WS-G5486 compatible GBIC transceiver provides 1000Base-LX throughput up to 10km over single-mode Fibre (SMF) at a wavelength of 1310nm using a SC connector. Our transceiver is guaranteed to be 100% compatible with the equivalent Cisco transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Cisco, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
