C2G XENPAK-10GB-SR 10GBase-SR Transceiver
£270.54
Delivery:
Key features
  • XENPAK Transceiver Module designed for use with Cisco network equipment
  • Functionally identical to Cisco XENPAK-10GB-SR
  • High speed 10-Gigabit connectivity
  • Transceiver type SR allows for connections up to 300m
  • SC ports designed for use with Multimode fiber
  • 850nm wavelength signaling
Product codes
This Cisco XENPAK-10GB-SR compatible XENPAK transceiver provides 10GBase-SR throughput up to 300m over multi-mode Fibre (MMF) at a wavelength of 850nm using a SC connector. Our transceiver is guaranteed to be 100% compatible with the equivalent Cisco transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Cisco, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
C2G - XENPAK transceiver module - 10 GigE
XENPAK transceiver module - SC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10 GigE
Max Transfer Distance
300 m
3.56 cm x 12.2 cm x 1.27 cm
336 g
P/N: WS-SUP32-10GE-3B, WS-SUP32-10GE-3B=, WS-SUP32-10GE-3B-RF, WS-X6704-10GE, WS-X6704-10GE=, WS-X6704-10GE-RF
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G XENPAK-10GB-SR 10G...
£270.54
