C2G XFP-10G-S 10GBase-SR XFP Transceiver
£217.10
Delivery:
Key features
  • XFP Transceiver Module designed for use with Juniper Networks network equipment
  • Functionally identical to Juniper Networks XFP-10G-S
  • High speed 10-Gigabit connectivity
  • Transceiver type SR allows for connections up to 300m
  • LC ports designed for use with Multimode fiber
  • 850nm wavelength signaling
Product codes
This Juniper Networks XFP-10G-S compatible XFP transceiver provides 10GBase-SR throughput up to 300m over multi-mode Fibre (MMF) at a wavelength of 850nm using a LC connector. Digital optical monitoring (DOM) support is also present to allow access to real-time operating parameters. Our transceiver is guaranteed to be 100% compatible with the equivalent Juniper Networks transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Juniper Networks, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
Product Description C2G - XFP transceiver module - 10 GigE
Device Type XFP transceiver module - LC multi-mode
Form Factor Plug-in module
Cabling Type 10GBase-SR
Data Transfer Rate 10 Gbps
Optical Wave Length 850 nm
Data Link Protocol 10 GigE
Max Transfer Distance 300 m
OEM Manufacturer Equivalent Part Number Juniper XFP-10G-S
Dimensions (WxDxH) 1.27 cm x 6.35 cm x 0.76 cm
Weight 90.7 g
Designed For Juniper M-series M120, M120-H, M120-L
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G XFP-10G-S 10GBase-...
£217.10
