C2G XFP10GLR-192SR-L 10GBase-LR Transceiver
£347.24
Delivery:
Key features
  • XFP Transceiver Module designed for use with Cisco network equipment
  • Functionally identical to Cisco XFP10GLR-192SR-L
  • High speed 10-Gigabit connectivity
  • Transceiver type LR allows for connections up to 10km
  • LC ports designed for use with Single-Mode fiber
  • 1310nm wavelength signaling
Product codes
This Cisco XFP10GLR-192SR-L compatible XFP transceiver provides 10GBase-LR throughput up to 10km over single-mode Fibre (SMF) at a wavelength of 1310nm using a LC connector. Digital optical monitoring (DOM) support is also present to allow access to real-time operating parameters. Our transceiver is guaranteed to be 100% compatible with the equivalent Cisco transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Cisco, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
C2G - XFP transceiver module - 10 GigE
XFP transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-LR
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 GigE
Max Transfer Distance
10 km
1.27 cm x 6.35 cm x 0.76 cm
90.7 g
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G XFP10GLR-192SR-L 1...
£347.24
