Cables Direct 15cm Leaded USB Type-C to DVI & USB Adapter
£22.89
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
The USB3C-DVIUSB-WPD is a USB-C to USB 3.0, DVI and USB-C charging port hub. The USB 3.0 port allows you to connect a USB device to the host computer or another hub. The USB-C female port can charge the host computer and supply power for the adapter at the same time. The DVI port allows you to connect an extra monitor so that you can watch videos or slideshows on the big screen.
It also features a USB-C female port so you can charge for the host computer and supply power for the adapter simultaneously. It can work on Macbook’s or Google’s new Chromebook Pixel as well as other USB-C supported devices.
Product Description Cables Direct - docking station - DVI
Product Type Docking station
Docking Interface USB-C
Video Interfaces DVI
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Cables Direct 15cm Lea...
£22.89
