Cables Direct 5m CAT6A SSTP-LSOH Patch Cable Snagless Red - B...
Cables Direct 5m CAT6A SSTP-LSOH Patch Cable Snagless Red - B/Q 50
£5.07
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
Category 6A Ethernet cable, commonly referred to as Cat6A, is a cable standard for 10 Gigabit Ethernet. The cable standard provides performance of up to 600MHz and is suitable for 10BASE-T, 100BASE-TX (Fast Ethernet), 1000BASE-T / 1000BASE-TX (Gigabit Ethernet) and 10GBASE-T (10 Gigabit Ethernet). It is backwards compatible with previous standards such as Cat6, Cat5e and Cat5.
  • LSZH: low Smoke Zero Halogen cable reduces the amount of toxic and corrosive gas emitted during a fire.
  • Supports 10 Gigabit Ethernet / 10GBASE-T: 10 Times faster than Gigabit Ethernet, 10GE (also called 10GbE or 10 GigE) supports a data rate of 10Gbits/s (billion bits per second).
  • S/FTP (or S/STP): Screened and Foil (Shielded) Twisted Pair. Each individual pair is screened by foil and features an overall outer sheath. This shielding protects the cable from EMI (Electro-Magnetic Interference).
  • Snagless Connectors: The connectors feature a "bubble" which protects the locking clip on the RJ45 from damage or being snapped off during transport or installation.
  • Flush Moulded Strain Relief: The flush moulded design allows the patch cables to be installed side by side in high-density network switches. The strain relief allows the cables to move without damaging the cable or breaking away from the connector while it is plugged in a device
  • This product has been tested and found to comply with the applicable electrical transmission characteristics specified in: ISO/IEC 11801 ED.2 and ANSI/TIA-568-C.2
  • IEC 60332-1-2, RoHS Compliant and 3P Verified
Cables Direct patch cable - 5 m - red
Patch cable - CAT 6a
Shielded foiled twisted pair (SFTP)
Wires per Cable
8 wires
Halogen-free, molded, snagless
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Red
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Cables Direct 5m CAT6A...
£5.07
