Cables Direct 5Mtr Reverse SMA M-F Extension Cable B/Q 200
Key features
  • Reverse SMA male-female cable
  • Flexible mini coax
Product codes
The NLWL-CAB05 wireless antenna extension cable is the perfect solution to positioning your Antenna for the best signal without moving your computer or router. The NLWL-CAB05 creates an extension of 5 meters. The cable is a thin flexible mini coax of 26 AWG, a braided shield and brass reverse SMA male-female connector.
Product Description NEWlink antenna extension cable - 5 m
Cable Antenna extension cable
Technology Coaxial
American Wire Gauge (AWG) 26
Length 5 m
Connector R-SMA - male
Connector (Second End) R-SMA - female
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Cables Direct 5Mtr Rev...
