Cables Direct Digital Audio Cable (optical) - TOSLINK (M) to...
Cables Direct Digital Audio Cable (optical) - TOSLINK (M) to TOSLINK (M) - 2m - Fibre Optic
£2.50
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Type: Toslink
  • Length: 2m
  • Stock Status: In Stock
Product codes
TOSLINK or Optical Cable is a fiber optic connection system. Most commonly used with audio equipment (via a "digital optical" socket,) where it carries a digital audio stream from devices such as CD, DVD, Blu-Ray players and modern video game consoles, to an AV receiver such as surround sound system that can decode the stream of audio and output it through a set of loudspeakers. Since TOSLINK uses fibre-optic cable, it is free from distortion caused by electrical or magnetic interference that an electrical cable would incur.
The result is an audio signal that is purer, as well as truer to the original recording. Gold plating is used on the connectors for its anti-corrosive properties.
Key Features:
  • Cable: Optical Fibre
  • Outside Diameter: 5mm
  • Length: 200cm
  • Colour: Black
  • Warranty: 1 year
  • Packaging: Polybag (OEM)
Product Description Cables Direct digital audio cable (optical) - 2 m
Cable Digital audio cable (optical)
Technology Fibre optic
Length 2 m
Connector TOSLINK - male
Connector (Second End) TOSLINK - male
Features Corrosion-resistant connectors
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Cables Direct Digital...
£2.50
