Cables Direct Leaded USB Type C to 2 Port USB Hub & Card...
Cables Direct Leaded USB Type C to 2 Port USB Hub & Card Reader
£27.26
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
The USB3C-HUB2CR-WPD is a USB-C to two port USB 3.0 hub with USB-C charging port and Micro SD and SD/MMC port. The USB 3.0 port allows you to connect a USB device or another hub to the host USB-C computer, the USB-C female port can charge the host computer, the Micro SD and SD/MMC port allows you to access memory cards on the host PC. It can work on Macbook’s or Google’s Chromebook Pixel as well as other USB-C supported devices.
Note: The Micro SD and SD/MMC port won’t work simultaneously, you can choose to use one of them according to your practical needs.
Cables Direct USB3C-HUB2CR-WPD - hub - 2 ports
Hub - 2 ports
Subtype
USB
Ports
2 x SuperSpeed USB 3.0
USB 2.0, USB 3.0
1 year warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Cables Direct Leaded U...
£27.26
