Cables Direct Leaded USB Type-C to 3 Port USB Hub & Card...
Cables Direct Leaded USB Type-C to 3 Port USB Hub & Card Reader
£13.56
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
The USB3C-HUB3CR is a USB-C to three USB 3.0 hub with a Micro SD and SD/MMC port. The USB 3.0 port allows you to connect a USB device or another hub to the host USB-C computer, the Micro SD and SD/MMC port allows you to access memory cards on the host PC. It can work with Macbook’s or Google’s Chromebook Pixel as well as other USB-C supported devices.
Product Description Cables Direct USB3C-HUB3CR - hub - 3 ports
Device Type Hub - 3 ports
Subtype USB
Ports 3 x SuperSpeed USB 3.0
Compliant Standards USB 2.0, USB 3.0
Manufacturer Warranty 1 year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Cables Direct Leaded U...
£13.56
