Cables Direct NELWINK 15CM V1.2 HDMI ADAP 4K
£11.82
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • DisplayPort input
  • HDMI high speed output
  • Active adapter
  • Fast bandwidth
  • 3D support
  • Audio support
  • Supports HDCP
  • Plug and Play
  • With ferrite
Product codes
The DisplayPort to HDMI cable adapter will allow you to connect a high definition monitor, projector or LCD TV to a laptop or graphics card with a DisplayPort connection. DisplayPort allows greater resolutions while maintaining high picture quality with an active chipset allowing the connection of multiple displays.
NEWlink - video converter
Video converter
1 x DisplayPort input - 20 pin DisplayPort , 1 x HDMI output - 19 pin HDMI Type A
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Cables Direct NELWINK...
£11.82
