Cables Direct Power Cable IEC 320 EN 60320 C15 (M) to BS 1363...
Cables Direct Power Cable IEC 320 EN 60320 C15 (M) to BS 1363 (M) - AC 250 V - 2m
£5.00
Delivery:
Standard: 1-3 working days
Express: Delivered on Monday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Product codes
The UK to IEC C15 mains cable, more commonly known as a kettle lead is used for powering a variety of electrical appliances such as PC base units, monitors, printers & photocopiers and a whole host of other equipment including high temperature devices such as kettles.
The C15 connector, although similar in appearance to the C13 has a higher temperature rating of 170 degrees rather than 70 degrees. You can tell the difference between a C13 and a C15 connector by the notch in the connector; this means a C15 plug will work with a C14 and a C16 socket. A C13 plug however will only work in a C14 socket.
Cables Direct power cable - 2 m
Power cable
Fuse, rubberised
Length
2 m
United Kingdom
Connector
Power IEC 60320 C15
Connector (Second End)
Power BS 1363 - male
Rated Voltage
AC 250 V
1 year warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Cables Direct Power Ca...
£5.00
