Cables Direct UK Single Back Box - 86mm x 86mm x 45mm - B/Q 100
£0.69
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
The UT-724D is a surface mounted single back box for 86mm wide faceplates. Has multi in and out points allowing easy access, 45mm deep to allow enough cable bend for most applications.
Cables Direct UT-724D - back box
Back box
Package Content
2 x screws
8.6 cm x 8.6 cm x 4.5 cm
Product Material
Plastic
White
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Cables Direct UK Singl...
£0.69
