The UT-722A is a surface mounting single back box for 86mm wide faceplates. Has multi in and out points allowing easy access, 32mm deep to allow enough cable bend for most applications.
Cables Direct UT-722A - back box
Back box
Package Content
2 x screws
8.6 cm x 8.6 cm x 3.2 cm
Product Material
Plastic
White
Back box
Package Content
2 x screws
Product Material
Plastic
8.6 cm
8.6 cm
3.2 cm
Enclosure Colour
White
Customer reviews
