Cables Direct USB2-GIGETHA Network Adapter
Product codes
The Gigabit USB 2.0 Ethernet adapter converts a USB port into a 10/100/1000 Base-T Ethernet port. It enables low cost and affordable Gigabit Ethernet network connection to any PC, laptop or embedded system by using your existing USB ports.
Product Description Cables Direct USB2-GIGETHA - network adapter
Device Type Network adapter
Form Factor External
Interface (Bus) Type USB 2.0
Ports Gigabit Ethernet
Cabling Type Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
Data Link Protocol 10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate 1 Gbps
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0
System Requirements Apple MacOS, Linux, Microsoft Windows
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Cables Direct USB2-GIG...
