Cables Direct VGA Cable HD-15 (M) to HD-15 (M) 20m Moulded -...
Cables Direct VGA Cable HD-15 (M) to HD-15 (M) 20m Moulded - Black
£14.58
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
Our range on Super VGA cables are constructed using UL2919 approved 28awg triple mini coaxial and 4x 28awg conductor cables, this allows them to be used for extended distances. Triple shielded with copper braid, foil and drain wire. Our cables are designed for standard monitors and widescreen LCD’s that require DDC cable.
Cables Direct VGA cable - 20 m
VGA cable
Triple shielded coaxial
Molded, drain wire
Length
20 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
UL 2919
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Cables Direct VGA Cabl...
£14.58
