Cables Direct VGA Extension Cable - HD-15 (M) to HD-15 (F) -...
Cables Direct VGA Extension Cable - HD-15 (M) to HD-15 (F) - 5m - Black
£5.26
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
Our range of Super VGA cables are constructed using UL2919 approved 28 AWG triple mini coaxial and 4x 28 AWG conductor cables, this allows them to be used for extended distances. Triple shielded with copper braid, foil and drain wire. This range of cables have all pins connected and should work with widescreen monitors that require DDC cables.
The DDC link is carried on three pins 12, 15 and 10 (data, clock and ground) in a 15-pin VGA connector.
Product Description Cables Direct VGA extension cable - 5 m
Type VGA extension cable
Technology Triple shielded
Length 5 m
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - female
Compliant Standards UL 2919, DDC
Colour Black
Manufacturer Warranty 1 year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Cables Direct VGA Exte...
£5.26
