Canon CanoScan LiDE220 A4 Flatbed Scanner
CLOUD CONNECTIVITY!
£75.16
Delivery:
Key features
  • Excellent resolution
  • High speed scan
  • EZ buttons
  • Auto document fix
  • Auto scan mode
  • Advanced Z-Lid expansion top
Product codes
The CanoScan LiDE220 Color Image Scanner offers advanced features, easy operation and "Send to Cloud" functionality. The LiDE220 lets you upload images to the Cloud with remarkable ease. Providing a maximum optical resolution of 4800 x 4800 dpi, its vivid 48-bit color depth is capable of producing over 281 trillion possible colors. An Auto Document Fix feature automatically produces beautiful scans with advanced image analysis and area-by-area data correction, while Auto Scan Mode automatically evaluates the item being scanned and saves it with the appropriate settings. The LiDE220 scanner also helps you work efficiently with five EZ Buttons that enable you to scan, copy, Send to Cloud, or create a single or multipage PDF in a snap. It scans fast too, creating a letter-sized color scan in approximately 10 seconds. Plus, it comes with a stand to enable vertical scanning - accommodating workspaces of just about any size. And the Advanced Z-Lid Expansion Top extends up approximately one-inch and over the platen to let you scan large items, such as textbooks or other thick documents. The LiDE220 scanner uses one USB cable for both data and power, so plugging in is easy. The LiDE 220 includes My Image Garden, a convenient software package that makes organizing your photos fun and easy.
Product Description Canon CanoScan LiDE220 - flatbed scanner - desktop - USB 2.0
Device Type Flatbed scanner - desktop
Interface Type USB 2.0
Scanning Sensor Type Contact Image Sensor (CIS)
Light Source RGB LED array
Max Supported Document Size 216 x 297 mm
Input Type Colour
Grayscale / Color Depth 16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External) 8-bit (256 grey levels) / 48-bit colour
Optical Resolution 4800 dpi x 4800 dpi
Interpolated Resolution 19200 dpi
Max Document Size 216 mm x 297 mm
Supported Document Type Plain paper
System Requirements Microsoft Windows 7, Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Apple MacOS X 10.6.8 or later, Windows 8, Windows 8.1
Microsoft Certification Compatible with Windows 7
Dimensions (WxDxH) 25 cm x 36.5 cm x 3.9 cm
Weight 1.6 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon CanoScan LiDE220...
£75.16
