Canon DR-F120 A4 Colour Document Scanner 20ppm Mono
£287.98
Delivery:
Key features
  • Wide range of use
  • Versatile, flexible, and adaptable
  • Simple to use
  • High quality imaging
  • Easy document processing
  • Environment in mind
Product codes
Maximised productivity
Capture various types of document accurately and efficiently with the DR-F120: a compact all-in-one scanning solution that offers both an automatic document feeder (ADF) and flatbed. You can save yourself valuable time using the 50-sheet document feeder, with its faster 20ppm scanning speeds. The DR-F120 can be relied on to get through your work with a suggested daily volume of up to 800 scans.
Effortless paper handling
The DR-F120 gives you complete flexibility to scan a wide range of materials despite its compact body size and small footprint. The straight-through ADF path accommodates A4-width documents, and media of up to 1,000mm in length. You’ll enjoy increased reliability and time-savings when scanning mixed documents with Canon’s dependable separation and feed roller mechanism. The flatbed scanner is ideal for handling media like books, passports or magazines, and effortlessly captures pages up to legal size. It’s equally at home with photos or other thick, thin and delicate documents.
Superior image quality
The DR-F120 delivers superior quality results time after time, due to its 600dpi scanning, wide range of built-in image enhancement features and Canon’s renowned imaging technology. You’ll achieve unprecedented colour accuracy that stays true to the original document via the scanner’s 3-Dimensional Color Correction function.
Simple, user-friendly operation
Achieve superb results with just a single touch of a button using the Full Auto Mode that automatically applies the best settings for each scanned image. Built-in tools eliminate blank pages and automatically detect paper size and text orientation; while the automatic deskew feature straightens documents fed at an angle. Frequent tasks can be made even simpler by assigning them to any of the 3 job buttons on the scanner panel.
Bundled software gives you more choice
The DR-F120 offers a simple and intuitive scanning experience using Canon’s CaptureOnTouch software. Users can scan, edit and send their documents even more easily with this versatile scanning solution. Its step-by-step, icon-based user interface lets users quickly convert their paper documents to multiple file formats (PDF, TIFF, JPEG, BMP, PNG and PowerPoint). CaptureOnTouch is equally capable as a simple document filing solution that lets users scan and create searchable PDF documents – including easy text-based search and retrieval. Cloud plug-ins to SharePoint, SugarSync, OneDrive, Dropbox, Google Drive™ and Evernote are included, ISIS and TWAIN drivers are also provided.
Easy to own and maintain
DR-F120 is easy to maintain because of its user-friendly design. The feed rollers are user-replaceable, which means you won’t incur the cost of calling out a service technician. Your costs stay low due to the scanner’s high energy-efficiency of just 28W in operation.
Product Description Canon imageFORMULA DR-F120 - document scanner - desktop - USB 2.0
Device Type Document scanner - desktop
Interface Type USB 2.0
Scanning Sensor Type CMOS / CIS
Light Source RGB LED array
Max Supported Document Size Legal (216 x 356 mm)
Input Type Colour
Grayscale / Color Depth (External) 8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 20 ppm (mono) / 10 ppm (colour)
Max Document Size 216 mm x 1000 mm
Automatic Duplexing Yes
Supported Document Type Plain paper
Document Feeder Type Automatic
Document Storage Capacity 50 sheets
Duty Cycle 800 scans per day
Power AC 230V (50/60 Hz)
System Requirements Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012
Microsoft Certification Compatible with Windows 7
Dimensions (WxDxH) 49.5 cm x 33.5 cm x 20.1 cm
Weight 4.6 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon DR-F120 A4 Colou...
£287.98
