Canon DR-M260 Document Scanner
£675.63
Delivery:
Standard: 1-3 working days
Key features
  • Slender, modern design
  • Fast scanning speeds
  • Virtuoso versatility
  • Quality and reliability
  • Simplified scanning
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: 216 x 5588 mm
  • Interface: USB 3.1 Gen 1
  • Stock Status: In Stock
Product codes
The compact imageFORMULA DR-M260 has a small frame, yet produces a big performance. This dependable scanner is packed with innovative features and delivers outstanding image quality, with capture speeds of up to 60 ppm/120 ipm.
Product Description Canon imageFORMULA DR-M260 - document scanner - desktop - USB 3.1 Gen 1
Device Type Document scanner - desktop
Interface Type USB 3.1 Gen 1
Scan Element Type CMOS / CIS
Light Source RGB LED array
Max Supported Document Size 216 x 5588 mm
Input Type Colour
Grayscale / Color Depth 8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 60 ppm (mono) / 60 ppm (colour)
Max Document Size 216 mm x 5588 mm
Automatic Duplexing Yes
Supported Document Type Plain paper, business card, passport, post card
Document Storage Capacity 80 sheets
Duty Cycle 7500 scans per day
Power AC 120/230 V (50/60 Hz)
System Requirements Microsoft Windows 7 (32/64 bits) SP1, Microsoft Windows Server 2008 R2 (32/64-bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits), Microsoft Windows Server 2012 R2 (32/64 bits), Microsoft Windows Server 2016 (32/64 bits)
Dimensions (WxDxH) 28.5 cm x 17.8 cm x 18 cm
Weight 3.6 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon DR-M260 Document...
£675.63
