Canon DR6010C Colour Document Scanner
£1,901.60
Delivery:
Standard: 1-3 working days
Key features
  • Speed to suit user needs
  • Flexible capabilities for seamless document handling
  • Dedicated features for detailed image capture
  • User-friendly solutions for capturing and distributing documents
  • Environment in mind
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: 218 x 356 mm
  • Interface: SCSI, USB 2.0
  • Compatibility: PC
Product codes
The imageFORMULA DR-6010C departmental scanner delivers high-speed, reliable document handling and high-quality images in a small package, with a daily duty cycle of 7,500. Flexibility, rich features, and ease-of-use help maximize return on investment at all levels of the business system.
Benefits
  • High speed colour scanning – 60 ppm at 200 & 300dpi
  • Front-Feed design & straight paper path option
  • Large 100 sheet feeding
  • Energy efficient
  • Advanced image processing
  • Robust - duty cycle of 7,500 scans/day
  • Bundled Capture Perfect
Detailed Features
Take a more detailed look into the Canon imageFORMULA DR-6010C
Productivity when it matters
The DR-6010C is our fastest departmental scanner yet, scanning a rapid 60-ppm in colour at resolutions of 200 & 300dpi. A large capacity 100 sheet automatic feeder enables significant batches to be processed, for more scans in less time.
Flexible and reliable feeding
Coupled with the operator appreciated front–feed design the DR-6010C also comes with a selectable straight paper path which can be used for the trouble-free scanning of plastic cards and thick cards up to 546g/m², or more fragile documents.
Energy efficient
The DR-6010C doesn’t just save time, it cuts energy consumption too, being one of the most energy efficient devices in its class.
Optimum quality
A huge range of powerful features such as Auto-Colour Detection, Text Orientation Recognition, Auto Paper Size and Deskew detection ensure superb quality and optimum efficiency.
Small yet built for tough workloads
Despite the DR-6010C being small enough to fit on any desktop it’s capable of taking on busy office requirements quickly and reliably with a suggested daily duty cycle of up to 7,500 scans a day.
User friendly
The DR-6010C can be used across a mixed range of business scanning applications. The Scan-To- Job buttons speed up productivity by allowing batches to be quickly scanned and sent to pre-defined destinations or workflow applications. Canon’s CapturePerfect software is bundled with the DR-6010C, with a Capture Perfect Software Developers Kit (SDK) also available for easy, customised integrations.
Product Description Canon imageFORMULA DR-6010C - document scanner - desktop - USB 2.0, SCSI
Device Type Document scanner - desktop
Interface Type USB 2.0, SCSI
Scan Element Type Contact Image Sensor (CIS)
Light Source RGB LED array
Max Supported Document Size 218 x 356 mm
Input Type Colour
Grayscale / Color Depth 8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 60 ppm (mono) / 60 ppm (colour)
Max Document Size 218 mm x 1000 mm
Automatic Duplexing Yes
Document Feeder Type Manual, automatic
Document Storage Capacity 100 sheets
Power AC 230V (50/60 Hz)
System Requirements Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Vista
Dimensions (WxDxH) 31.8 cm x 27.8 cm x 18.6 cm
Weight 6.5 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon DR6010C Colour D...
£1,901.60
