Canon i-SENSYS FAX-L150 Mono Laser Multifunction Printer
£169.47
14 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Fast, cost-effective faxing
  • Greater efficiency
  • Quick, simple operation
  • More productive working
  • Fast printing and copying
  • Simple maintenance
  • Exceptional energy efficiency
  • Type: Copier / fax / printer
  • Functionality: Copier, Fax, Printer
  • Output Type: Monochrome
  • Wireless Capability: Wired
  • Technology: Laser
Product codes
i-SENSYS FAX-L150 has a cost-effective all-in-one cartridge, which contains toner, drum and all essential parts. Simply replace the cartridge in seconds - there's no mess or hassle. Use an authentic Canon cartridge and you can be sure of continuous high quality output.
Product Description Canon i-SENSYS FAX-L150 - multifunction printer - B/W
Device Type Multifunction printer
Copier Type Digital
Fax Type Super G3 - plain paper
Printing Technology Laser (monochrome)
Monthly Duty Cycle (max) 8000 impressions
Max Copying Speed Up to 11.8 ppm
Max Copying Resolution Up to 600 x 600 dpi
Max Printing Speed Up to 18 ppm
Max Fax Transmission Speed 33.6 Kbps
Data Compression System MH, MR, MMR
Fax Resolutions 200 x 400 dpi
Original Size 127 x 139.7 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type Sheets
Document Feeder Capacity 30 sheets
Media Size 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper
Standard Media Capacity 150 sheets
Output Trays Capacity 100 sheets
Connection Availability Yes
Interface USB 2.0
Office Machine Features Ultra High Quality (UHQ) image processing
Power AC 230 V (50/60Hz)
Dimensions (WxDxH) 37.2 cm x 30.3 cm x 30.3 cm
Weight 8.6 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon i-SENSYS FAX-L15...
£169.47
