Canon i-SENSYS FAX-L150 Mono Laser Multifunction Printer
£169.47
12 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Fast, cost-effective faxing
  • Greater efficiency
  • Quick, simple operation
  • More productive working
  • Fast printing and copying
  • Simple maintenance
  • Exceptional energy efficiency
Product codes
    Cut your communication costs down to a minimum with this super G3 fax, which transmits documents in as little as 3 seconds per page. As faxes can be sent and received in the shortest time possible, the telephone line is freed up.
    A 512-page memory safely stores all incoming documents so you can print out faxes later if paper or toner run out. Lengthy documents can also be scanned into the memory to be sent automatically, cutting transmission time and fax costs.
    Dialing couldn't be simpler, even for inexperienced users, with all your regular numbers accessed by 15 one-touch and 100 coded speed dials. A clear, intuitive 5-line LCD display makes this fax particularly easy to use.
    Thanks to the 30-page automatic document feeder, users can fax or copy lengthy documents smoothly, in a single operation, rather than feeding them through a page at a time. A 150-sheet capacity paper tray also saves time refilling paper.
    Use this fax as a productive 18-page-per-minute laser printer via the USB connection. With Quick First Print technology there is a fast warm-up time from sleep mode. You can also copy documents at 11.8 pages per minute.
    i-SENSYS FAX-L150 has a cost-effective all-in-one cartridge, which contains toner, drum and all essential parts. Simply replace the cartridge in seconds - there's no mess or hassle. Use an authentic Canon cartridge and you can be sure of continuous high quality output.
    This environmentally friendly fax has class-leading energy efficiency, consuming only 1.5 watts in sleep mode.
Canon i-SENSYS FAX-L150 - multifunction printer (B/W)
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
8000 impressions
Max Copying Speed
Up to 11.8 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 18 ppm
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR
Fax Resolutions
200 x 400 dpi
Original Size
127 x 139.7 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper
Standard Media Capacity
150 sheets
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0
Office Machine Features
Ultra High Quality (UHQ) image processing
AC 230 V (50/60Hz)
37.2 cm x 30.3 cm x 30.3 cm
8.6 kg
Environmental Standards
ENERGY STAR Qualified
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon i-SENSYS FAX-L15...
£169.47
