Canon i-SENSYS FAX-L410 Mono Laser Multifunction Printer
£517.30
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Fast faxing
  • More productive, trouble-free faxing
  • Increased efficiency
  • Use less paper and reduce wasted time
  • Fast laser printing
  • Highly energy efficient
  • Type: Copier / fax / printer
  • Functionality: Copier, Fax, Printer
  • Output Type: Monochrome
  • Wireless Capability: Wired
  • Technology: Laser
Product codes
Industry-fastest, laser fax machine with duplex ADF is ideal for robust, everyday use. This robust, compact Super G3 laser fax machine, with its large LCD display, fast performance and automatic duplex ADF, is ideal for everyday use within any business.
The i-SENSYS FAX-L410 simplifies usability with its intuitive, large LCD display. Faxing is quicker through the 39 one-touch and 200 coded speed dials, which stores regularly used numbers so they do not need to be redialed every time. The 250-sheet paper capacity minimizes the time spent refilling the cassette.
Product Description Canon i-SENSYS FAX-L410 - multifunction printer - B/W
Device Type Multifunction printer
Copier Type Digital
Fax Type Super G3 - plain paper
Printing Technology Laser (monochrome)
Monthly Duty Cycle (max) 10000 impressions
Max Copying Speed Up to 25 ppm
Max Copying Resolution Up to 600 x 600 dpi
Max Printing Speed Up to 25 ppm
Max Fax Transmission Speed 33.6 Kbps
Data Compression System MH, MR, MMR
Fax Resolutions 200 x 400 dpi
Original Size 127 x 140 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type Sheets
Document Feeder Capacity 50 sheets
Media Size 76.2 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper
Standard Media Capacity 250 sheets
Output Trays Capacity 100 sheets
Automatic Duplexing Yes (copying) Yes (printing)
Connection Availability Yes
Interface USB 2.0
Office Machine Features Ultra High Quality (UHQ) image processing
Power AC 230 V (50/60Hz)
Dimensions (WxDxH) 47.2 cm x 44.5 cm x 35.8 cm
Weight 13.9 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon i-SENSYS FAX-L41...
£517.30
