Canon i-SENSYS LBP352x A4 Mono Laser Printer
£730.44
Delivery:
Standard: 1-3 working days
Key features
  • Prints at a rapid 62 ppm
  • Suitable for all environments thanks to its small footprint
  • Print from smartphones and tablets with support for mobile printing
  • Easily manage as part of your network
  • Simple double-sided printing to reduce waste and save costs
  • Type: Printer
  • Functionality: Printer
  • Output Type: Monochrome
  • Wireless Capability: Wired
  • Technology: Laser
Product codes
A fast black-and-white laser printer in a compact form factor with flexible media handling capabilities, making it ideal for demanding environments that need versatility and speed.
Benefits
  • Prints at a rapid 62ppm
  • Highly productive with an expandable paper capacity up to 3,600 pages and a range of optional cassette configurations
  • Efficient to run, using high-capacity Canon toner cartridges
  • Optional secure printing and storage
Take a more detailed look into the Canon i-SENSYS LBP352x
Fast and flexible printing-
With black-and-white printing at 62ppm and a choice of flexible configurations, the LBP352x is ideal for busy working environments that demand a reliable and versatile printer. A choice of up to four paper cassettes, plus an optional high-capacity paper deck, makes it an easily configurable and highly productive printer.
High-capacity in a small footprint-
To be productive, you need a high-capacity printer, so that’s why the LBP352x has a large 600-page capacity as standard, expandable to 3,600 pages. A compact and capable office companion, this larger capacity still comes in a small package. There is also a high yield toner cartridge that allows you to print more pages before replacement, making you even more productive. Whatever the printing task, the LBP352x is built for versatility. From A5 to A4 double-sided documents, it’s ready to deliver in seconds.
Cloud and mobile printing-
Thanks to the LBP352x’s support for Apple AirPrint (iOS) and Mopria (Android), you can print easily from any compatible device. You can also benefit from more advanced features with the Canon PRINT Business app. For those using Google in the workplace, the LBP352x comes Google Cloud print-ready for seamless integration.
Smart networking and management capabilities-
The LBP352x is a superbly versatile addition to your printer fleet. Support for PCL5e/6 and Adobe PostScript printer languages enable hassle-free integration into managed network environments. The LBP352x is equally well-suited to managed print service environments and is compatible with Canon’s e-Maintenance remote service management system The LBP352x can also be integrated into Canon’s uniFLOW output management platform, bringing you the efficiency and security of My Print Anywhere plus the added benefits of accounting and cost recovery.
Product Description Canon i-SENSYS LBP352x - printer - B/W - laser
Printer Type Workgroup printer - laser - B/W
Weight 26.2 kg
Media Size Class A4/Legal
Max Media Size Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom) 76 mm x 127 mm
Max Media Size (Custom) 216 mm x 356 mm
Print Speed Up to 62 ppm - B/W - A4 (210 x 297 mm) , Up to 41.4 ipm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W) 1200 x 1200 dpi
Automatic Duplexing Yes
Interface USB 2.0, Gigabit LAN, USB host
AirPrint Enabled Yes
RAM Installed (Max) 1 GB
Language Simulation PCL 5E, PostScript, PCL 6, PDF, Canon Ultra Fast Rendering (UFRII), TIFF
Media Type Envelopes, labels, plain paper, heavy-weight paper, cards
Total Media Capacity 600 sheets
Media Handling 500-sheet paper cassette, 100-sheet multipurpose tray
Monthly Duty Cycle (max) 280000 pages
Recommended Monthly Volume 5000 - 20000 pages
Networking Print server
Power AC 230V
System Requirements Linux, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5.8 or later, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Android, Windows 8, Apple iOS, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10
Dimensions (WxDxH) 41.5 cm x 52.9 cm x 43.8 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon i-SENSYS LBP352x...
£730.44
