Canon i-SENSYS LBP712Cx A4 Colour Laser Printer
£499.41
Delivery:
Key features
  • Rapid color printing at 38 ppm
  • Suitable for a variety of environments thanks to its small footprint
  • Print from smartphones and tablets with support for mobile printing
  • Auto toner seal removal for easier cartridge installation
  • Easy double-sided printing to reduce costs and waste
Product codes
With fast, high-quality color laser printing and flexible configuration options to provide a large paper capacity, this compact printer lets your workplace be even more productive.
Benefits
  • Rapid colour printing at 38ppm
  • Increased productivity delivered by an expandable page capacity to 2,300 with optional paper cassettes and configuration options
  • Efficient to run, with higher capacity Genuine Canon toner cartridges
  • New high performance S Toner for faster, energy efficient printing
  • Simple to manage as part of your network
  • Optional secure printing and storage
Fast and flexible printing-
With full colour printing at 38ppm, the LBP712Cx is ideal for busy working environments that demand a reliable, versatile printer. The ability to have up to 4 high-capacity paper feeder cassettes makes it perfect for the modern connected workplace.
High-capacity in a small footprint-
To be productive, you need a high-capacity printer, so that’s why the LBP712Cx has a large 650-page capacity as standard, expandable to 2,300 pages. A compact and capable office companion, this larger capacity still comes in a small package. Whatever the printing task, the LBP712Cxis built for versatility. From A5 to A4 double-sided documents, it’s ready to deliver in seconds.
Working on the go-
Thanks to the LBP712Cx’s support for Apple AirPrint (iOS) and Mopria (Android), you can print easily from any compatible device. You can also benefit from more advanced features with the Canon PRINT Business app. For those using Google in the workplace, the LBP712Cx comes Google Cloud print-ready for seamless integration.
Higher capacity toner cartridges-
Canon has redesigned its toner cartridges to be better than ever. The toner seal inside the cartridge is now automatically removed when the cartridge is fitted, cutting down on waste and installation time. In the same compact size, the new Genuine Canon toner cartridges now have a higher capacity, letting you be even more productive.
Canon’s exceptional image quality-
Whether you are printing presentations for important meetings or brochures to share with customers, the LBP712Cx produces superior colour graphics, images and text in laser quality prints to make a greater impact on the reader. Canon’s renowned image expertise ensures that businesses of any size can produce professional looking documents with fine lines, crisp text and high resolution – creating the positive impression modern businesses want to make.
Smart networking capabilities-
The LBP712Cx is a superbly versatile addition to your printer fleet. Support for PCL5e/6 and Adobe PostScript printer languages enable hassle-free integration into managed network environments. The LBP712Cx is equally well-suited to managed print service environments and is compatible with Canon’s e-Maintenance remote service management system The LBP712Cx can also be integrated into Canon’s uniFLOW output management platform, bringing you the efficiency and security of My Print Anywhere plus the added benefits of accounting and cost recovery.
Product Description Canon i-SENSYS LBP712Cx - printer - colour - laser
Printer Type Workgroup printer - laser - colour
Weight 28.8 kg
Media Size Class A4/Legal
Max Media Size Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom) 76.2 mm x 127 mm
Max Media Size (Custom) 216 mm x 356 mm
Print Speed Up to 38 ppm - B/W - A4 (210 x 297 mm) , Up to 38 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 38 ppm - colour - A4 (210 x 297 mm) , Up to 38 ipm - colour duplex - A4 (210 x 297 mm)
Max Resolution (B&W) 9600 x 600 dpi
Max Resolution (Colour) 9600 x 600 dpi
Automatic Duplexing Yes
Interface USB 2.0, Gigabit LAN, USB host
AirPrint Enabled Yes
RAM Installed (Max) 1 GB
Language Simulation PCL 5C, PostScript, PCL 6, PDF, Canon Ultra Fast Rendering (UFRII), TIFF
Media Type Envelopes, labels, plain paper, heavy-weight paper, cards, recycled paper
Total Media Capacity 650 sheets
Media Handling 100-sheet multipurpose tray, 550-sheet paper cassette
Monthly Duty Cycle (max) 80000 pages
Recommended Monthly Volume 2000 - 7500 pages
Networking Print server
Power AC 230V
System Requirements Linux, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Android, Apple MacOS X 10.6.8 or later, Windows 8, Apple iOS, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10
Dimensions (WxDxH) 45.8 cm x 46.4 cm x 38.8 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon i-SENSYS LBP712C...
£499.41
