Canon i-SENSYS LBP7660Cdn Colour Laser Printer
Key features
  • 20 ppm color and mono laser printing
  • 9600 x 600 dpi print resolution
  • Intuitive operation panel
  • Gigabit Ethernet
  • Energy efficient
  • Easy toner cartridge replacement
Product codes
For high quality output the i-SENSYS LBP7660Cdn has 9600 x 600 dpi print resolution that's enhanced with automatic image refinement for a perfect finish on every print. The printer comes with 768 MB of memory as standard, giving it the capacity to cope with large, complex documents and graphics, as well as the demands of network printing.
The i-SENSYS LBP7660Cdn integrates seamlessly into your business operations through its support for the industry-standard PCL5c/6. With built-in Gigabit Ethernet connection, it can also handle demanding workloads to ensure optimum network performance.
The superior energy efficiency of the i-SENSYS LBP7660Cdn means you can cut costs - as well as your impact on the environment. ENERGY STAR compliant, it consumes only 1.0 watts of power in sleep mode and has a low Typical Energy Consumption (TEC) figure, to make it one of the most efficient in its class. With automatic double-sided printing built-in you can reduce paper usage, not only saving money but also being more considerate to the environment.
Canon i-SENSYS LBP7660Cdn - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
25.2 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
215.9 mm x 355.6 mm
Print Speed
Up to 20 ppm - B/W - A4 (210 x 297 mm) , Up to 20 ppm - colour - A4 (210 x 297 mm)
Max Resolution (Colour)
9600 x 600 dpi
Image Enhancement Technology
Automatic Image Refinement
Automatic Duplexing
USB, Gigabit LAN
RAM Installed (Max)
768 MB
Language Simulation
PCL 5C, PCL 6, Canon Ultra Fast Rendering (UFRII)
Media Type
Envelopes, transparencies, labels, plain paper, coated paper, heavy-weight paper
Total Media Capacity
300 sheets
Media Handling
50-sheet multipurpose tray, 250-sheet paper cassette
Monthly Duty Cycle (max)
60000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
AC 230V
Linux, Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.4.9 - 10.7.x
41.4 cm x 49.9 cm x 34.6 cm
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon i-SENSYS LBP7660...
