Enjoy this connected 4-in-1 mono laser printer, built to deliver everything, a small office needs: print, copy, scan and fax from PCs, smartphones and tablets.
An ideal office companion
If you run a small business or work from a home office, you’ll appreciate the fast, reliable mono print quality, touchscreen display and print, copy, scan and fax.
Monitor from a PC or mobile
Access printer information, change network settings, set up the address book and check toner levels – all from the Remote User Interface (RUI).
Sustainability matters
The printer’s ECO reports make it easy to monitor and track usage, while Auto Off and reduced power consumption modes help keep your carbon footprint to a minimum.
Product Description | Canon i-SENSYS MF237w - B/W | Printing Technology | Laser (monochrome) | Original Type | Sheets | Media Type | Envelopes, plain paper, labels | Automatic Duplexing | Yes (printing) | Connection Availability | Yes | AirPrint Enabled | Yes | Power | AC 230 V | Manufacturer Warranty | 2 Years |
General | |
Printing Technology | Laser - monochrome |
Copying | |
Grayscale Half-Tones | 256 |
Max Document Reduction | 25% |
Printing | |
Automatic Duplexing | Yes |
Scanning | |
Colour Depth | 24-bit |
Document & Media Handling | |
Supported Media Type | Envelopes, plain paper, labels |
Power | |
Voltage Required | AC 230 V |
Environmental Parameters | |
Max Operating Temperature | 30 °C |
Manufacturer Warranty | |
Service & Support | 2 Years |
Customer return - item has been opened but is in excellent condition
Ref: GV4N 046503 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
£227.80
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
