General |
Printer Fonts |
PCL x 93 , PostScript x 136 |
Device Type |
Multifunction printer |
Fax Type |
Plain paper |
Printing Technology |
Laser - monochrome |
Monthly Duty Cycle (max) |
80000 pages |
Recommended Monthly Volume |
750 - 4000 pages |
Colour Support |
Colour |
Display Features |
Touch screen |
Connection Availability |
Yes |
Interface |
USB 2.0, Gigabit LAN, Wi-Fi(n) |
AirPrint Enabled |
Yes |
Office Machine Features |
Print from USB flash drive, scan to e-mail, Google Cloud Print ready, Mopria certified, scan to SMB, iFAX, barcode printing |
Memory |
Standard Memory |
1 GB |
Copying |
Max Copying Speed |
Up to 38 ppm |
Max Copying Resolution |
Up to 600 x 600 dpi |
Grayscale Half-Tones |
256 |
Max Document Enlargement |
400% |
Max Document Reduction |
25% |
Maximum Copies |
999 |
Exposure Modes |
Text, photo, text and photo |
Automatic Duplexing |
Yes |
Copying Features |
2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy |
Printing |
Max Printing Resolution |
Up to 1200 x 1200 dpi |
Max Printing Speed |
Up to 38 ppm |
Printer Drivers / Emulations |
PCL 5e, PCL 6, PostScript 3, PDF, TIFF, UFRII, JPEG |
Yes |
First Print Out Time B/W |
5.5 sec |
Scanning |
Yes |
Optical Resolution |
600 x 600 dpi |
Interpolated Resolution |
9600 x 9600 dpi |
Colour Depth |
24-bit |
Colour Depth (Internal) |
24-bit |
Fax Machine |
Compatibility |
Super G3 |
Max Transmission Speed |
33.6 Kbps |
Fax Resolutions |
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi |
Total Memory Capacity |
Up to 512 pages |
PC Faxing |
Yes (send only) |
Fax Machine Features |
Error Correction Mode (ECM) |
Yes |
Speed Dialing |
281 station(s) |
Telephone / Fax Switch |
Yes |
Broadcast Transmission |
310 stations |
Features |
Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, answering machine interface, remote reception, Dual Access, fax activity reports |
Document & Media Handling |
Min Original Size |
105 x 128 mm |
Max Original Size |
A4 (210 x 297 mm), Legal (216 x 356 mm) |
Supported Original Sizes |
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm) |
Original Type |
Sheets |
Document Feeder Capacity |
50 sheets |
Min Media Size |
76.2 x 127 mm |
Max Media Size |
A4/Legal |
Min Media Weight |
52 g/m² |
Max Media Weight |
163 g/m² |
Supported Media Type |
Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, postcards |
Supported Media Sizes |
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm) |
Supported Envelope Sizes |
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm) |
Standard Media Capacity |
350 sheets |
Bypass Feeder Capacity |
100 sheets |
Output Trays Capacity |
150 sheets |
Document & Media Handling Details |
ADF - 50 sheets size: 105 x 128 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 250 sheets size: 105 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 163 g/m² , Output tray - 150 sheets |
Speed Details |
Printing: up to 38 ppm (A4) - B/W , Printing: up to 63.1 ppm (A5) - B/W , Printing: up to 30.3 ipm (A4) - B/W duplex , Copying: up to 38 ppm (A4) - B/W , Copying: up to 30.3 ipm - B/W duplex , Scanning: up to 38 ipm - B/W , Scanning: up to 13 ipm - colour , Scanning: up to 70 ipm - B/W duplex , Scanning: up to 26 ppm - colour duplex |
Connections |
Interfaces |
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 |
Security Protocols & Features |
Secure Print, SSL, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, PING, ARP, MAC address filtering |
Operating System Support |
Linux, MS Windows 7, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Apple Mac OS X 10.8.5 or later, MS Windows Server 2016 |
Software Included |
Drivers & Utilities, iW Management Console, uniFLOW online, uniFLOW online Express |
Power |
Voltage Required |
AC 230 V (50/60Hz) |
Power Consumption Operational |
1300 Watt |
Power Consumption Standby |
10 Watt |
Power Consumption Sleep |
0.9 Watt |
Miscellaneous |
First Copy Out Time B/W |
6.6 sec |
Consumables Included |
1 x Cartridge (black) - up to 3100 pages - Canon 052 |
Dimensions & Weight |
Width |
45.3 cm |
Depth |
46.4 cm |
Height |
39.2 cm |
Weight |
16.9 kg |
Environmental Parameters |
Sound Emission |
55 dB (operating) |
Min Operating Temperature |
10 °C |
Max Operating Temperature |
30 °C |
Humidity Range Operating |
20 - 80% (non-condensing) |
