Canon i-SENSYS MF429x Mono Laser Multifunction Printer
£295.66
17 in stock
Delivery:
Standard: 1-3 working days
Key features
  • uniFLOW ready - controls access, costs, security and authentication
  • Application library - customized and automated functions
  • Simple to use - five-inch LCD color touchscreen
  • Fast printing speeds - up to 38ppm print speed
  • Quick scanning - double-sided single pass scanning
  • Universal Login Manager - enhances security, productivity, and control
  • Mobile connectivity - mobile apps allow secure printing from smart phones or tablets
  • Security - via PIN access to print
  • Type: Fax / copier / printer / scanner
  • Functionality: Copier, Fax, Printer, Scanner
  • Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
  • Stock Status: In Stock
Product codes
The i-SENSYS MF420 series are multi-function printers offering SMEs speed, durability, and quality. Mobile connectivity maximises productivity.
  • Save time with fast print speeds of up to 38ppm
  • Increase productivity with double sided single pass scanning
  • High quality 1200 x 1200 dpi print resolution
  • Easy operation with large colour touch screen
  • Improved flexibility with varied media support; A4, A5,A6
  • Increase control with the Universal Login Manager (MF428x and MF429x)
  • Enhanced security & accounting with uniFLOW (MF428x and MF429x)
  • Improve quality & reliability with Canon Genuine all-in-one cartridges
  • Application Library allowing automation, added shortcuts and a customised interface
  • Secure PIN feature allowing employers and employees maximum control over print jobs
Product Description Canon i-SENSYS MF429x - multifunction printer - B/W
Device Type Multifunction printer
Fax Type Super G3 - plain paper
Printing Technology Laser (monochrome)
Monthly Duty Cycle (max) 80000 pages
Recommended Monthly Volume 750 - 4000 pages
Max Copying Speed Up to 38 ppm
Max Copying Resolution Up to 600 x 600 dpi
Max Printing Speed Up to 38 ppm
Max Printing Resolution Up to 1200 x 1200 dpi
Max Fax Transmission Speed 33.6 Kbps
Fax Resolutions 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning 600 x 600 dpi
Original Size 105 x 128 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type Sheets
Document Feeder Capacity 50 sheets
Media Size 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, postcards
Standard Media Capacity 350 sheets
Bypass Feeder Capacity 100 sheets
Output Trays Capacity 150 sheets
Automatic Duplexing Yes (copying) Yes (printing) Yes (scanning)
Connection Availability Yes
Interface USB 2.0, Gigabit LAN, Wi-Fi(n)
AirPrint Enabled Yes
Office Machine Features Print from USB flash drive, scan to e-mail, Google Cloud Print ready, Mopria certified, scan to SMB, iFAX, barcode printing
Power AC 230 V (50/60Hz)
Dimensions (WxDxH) 45.3 cm x 46.4 cm x 39.2 cm
Weight 16.9 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon i-SENSYS MF429x...
£295.66
