We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Print, scan, copy and fax from this compact model, which also benefits from customisable controls, single-pass double-sided scanning and versatile mobile printing options.
Keep your business running smoothly with a robust black and white laser with print, scan, copy and fax functionality. Push productivity with rapid A4 print speeds of up to 38 ppm, double-sided single-pass scanning and double-sided printing, and get your workforce up to speed with customised controls. Tailor the printer to fit your business' needs with the Application Library and automate daily tasks or personalise on-panel functions. Control couldn't be simpler using the 12.7 cm colour touchscreen or via a smart device – seamless wireless connectivity means you can print, scan, copy and connect to the cloud via the Canon PRINT app or print straight away with AirPrint (iOS) and Mopria (Android). For security, take advantage of Secure PIN Printing.
Product Description | Canon i-SENSYS MF445dw - multifunction printer - B/W | Device Type | Multifunction printer | Fax Type | Super G3 - plain paper | Printing Technology | Laser (monochrome) | Monthly Duty Cycle (max) | 80000 pages | Recommended Monthly Volume | 750 - 4000 pages | Max Copying Speed | Up to 38 ppm | Max Copying Resolution | Up to 600 x 600 dpi | Max Printing Speed | Up to 38 ppm | Max Printing Resolution | Up to 1200 x 1200 dpi | Max Fax Transmission Speed | 33.6 Kbps | Fax Resolutions | 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi | Scanning | 600 x 600 dpi | Original Size | 105 x 128 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max) | Original Type | Sheets | Document Feeder Capacity | 50 sheets | Media Size | 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max) | Media Type | Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, postcards | Standard Media Capacity | 350 sheets | Bypass Feeder Capacity | 100 sheets | Output Trays Capacity | 150 sheets | Automatic Duplexing | Yes (copying) Yes (printing) Yes (scanning) | Connection Availability | Yes | Interface | USB 2.0, Gigabit LAN, Wi-Fi(n), USB host | AirPrint Enabled | Yes | Office Machine Features | Print from USB flash drive, scan to e-mail, scan to Cloud, iFAX | Power | AC 230 V (50/60Hz) | Dimensions (WxDxH) | 45.3 cm x 46.4 cm x 39.2 cm | Weight | 17.2 kg | Manufacturer Warranty | 2-year Limited Warranty |
General | |
Printer Fonts | PCL x 45 , PostScript 3 x 136 |
Fax Type | Plain paper |
Printing Technology | Laser - monochrome |
Display Colour Support | Colour |
Display Features | Touch screen |
Memory | |
Standard Memory | 1 GB |
Copying | |
Grayscale Half-Tones | 256 |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 999 |
Exposure Modes | Text, photo, text and photo |
Automatic Duplexing | Yes |
Copying Features | 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy |
Printing | |
Printer Drivers / Emulations | PCL 6, PostScript 3, PCL 5c, PDF, TIFF, UFRII, JPEG |
First Print Out Time B/W | 5.5 sec |
Scanning | |
Optical Resolution | 600 x 600 dpi |
Interpolated Resolution | 9600 x 9600 dpi |
Colour Depth | 24-bit |
Colour Depth (Internal) | 24-bit |
Fax Machine | |
Compatibility | Super G3 |
Max Transmission Speed | 33.6 Kbps |
Total Memory Capacity | Up to 512 pages |
PC Faxing | Yes (send only) |
Fax Machine Features | |
Error Correction Mode (ECM) | Yes |
Speed Dialing | 281 station(s) |
Telephone / Fax Switch | Yes |
Broadcast Transmission | 310 stations |
Features | Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, group dialling, remote reception, Dual Access, Double Sided Faxing, fax memory backup, fax activity reports |
Document & Media Handling | |
Min Original Size | 105 x 128 mm |
Max Original Size | A4 (210 x 297 mm), Legal (216 x 356 mm) |
Supported Original Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 105 x 128 mm |
Min Media Size | 76.2 x 127 mm |
Max Media Size | A4/Legal |
Min Media Weight | 60 g/m² |
Max Media Weight | 163 g/m² |
Supported Media Type | Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, postcards |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm) |
Supported Envelope Sizes | International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm) |
Document & Media Handling Details | DSDF - 50 sheets size: 105 x 128 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets |
Speed Details | Printing: up to 38 ppm (A4) - B/W , Printing: up to 63.1 ppm (A5) - B/W , Printing: up to 31.9 ipm (A4) - B/W duplex , Copying: up to 38 ppm (A4) - B/W , Copying: up to 30.3 ipm - B/W duplex , Scanning: up to 38 ipm - B/W , Scanning: up to 13 ipm - colour , Scanning: up to 70 ipm - B/W duplex , Scanning: up to 26 ipm - colour duplex |
Connections | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A |
Security Protocols & Features | Secure Print, SSL, Apple Bonjour, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, PING, ARP, MAC address filtering, SNMP 3 |
Operating System Support | Linux, MS Windows 7, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Apple Mac OS X 10.9.5 or later, MS Windows Server 2016, macOS 10.14, MS Windows Server 2019 |
Software Included | Drivers & Utilities, iW Management Console |
Power | |
Voltage Required | AC 230 V (50/60Hz) |
Power Consumption Operational | 1370 Watt |
Power Consumption Standby | 9.4 Watt |
Power Consumption Sleep | 0.9 Watt |
Miscellaneous | |
Warm-Up Time | 14 sec |
Consumables Included | 1 x Cartridge (black) - up to 3100 pages - Canon 057 |
Dimensions & Weight | |
Width | 45.3 cm |
Depth | 46.4 cm |
Height | 39.2 cm |
Weight | 17.2 kg |
Environmental Parameters | |
Sound Emission | 53 dB (operating) |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 30 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
Manufacturer Warranty | |
Service & Support | 2-year Limited Warranty |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
