Canon i-SENSYS MF445dw Mono Laser Multifunction Printer
£345.49
12 in stock
Delivery:
Standard: 1-3 working days
Key features
  • True multifunctionality: print, copy, scan and fax
  • Intuitive control with 12.7cm LCD touchscreen
  • Compact space-saving design
  • Rapid print speeds
  • Secure printing: PIN document release
  • Mobile printing
  • Type: Fax / copier / printer / scanner
  • Functionality: Copier, Fax, Printer, Scanner
  • Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
  • Stock Status: In Stock
Product codes
Print, scan, copy and fax from this compact model, which also benefits from customisable controls, single-pass double-sided scanning and versatile mobile printing options.
Product Description Canon i-SENSYS MF445dw - multifunction printer - B/W
Device Type Multifunction printer
Fax Type Super G3 - plain paper
Printing Technology Laser (monochrome)
Monthly Duty Cycle (max) 80000 pages
Recommended Monthly Volume 750 - 4000 pages
Max Copying Speed Up to 38 ppm
Max Copying Resolution Up to 600 x 600 dpi
Max Printing Speed Up to 38 ppm
Max Printing Resolution Up to 1200 x 1200 dpi
Max Fax Transmission Speed 33.6 Kbps
Fax Resolutions 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning 600 x 600 dpi
Original Size 105 x 128 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type Sheets
Document Feeder Capacity 50 sheets
Media Size 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, postcards
Standard Media Capacity 350 sheets
Bypass Feeder Capacity 100 sheets
Output Trays Capacity 150 sheets
Automatic Duplexing Yes (copying) Yes (printing) Yes (scanning)
Connection Availability Yes
Interface USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled Yes
Office Machine Features Print from USB flash drive, scan to e-mail, scan to Cloud, iFAX
Power AC 230 V (50/60Hz)
Dimensions (WxDxH) 45.3 cm x 46.4 cm x 39.2 cm
Weight 17.2 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon i-SENSYS MF445dw...
£345.49
