Canon i-SENSYS MF515x A4 Mono Multifunction Laser Printer
Key features
  • High-quality printing at an impressively fast 40 ppm
  • Color touch screen enables easy operation for all levels of user
  • Supports Secure PIN printing
  • Print from smartphones and tablets
  • Automatic duplex printing reduces waste and consumables overheads
  • Quick First-Print cuts waiting time and helps maximize workgroup productivity
  • Easily work with documents remotely via the cloud
  • Device and output management capabilities
Product codes
The MF515x black and white A4 laser Multifunctional printer is ideal for enterprise workgroups that want fast, professional-quality output capabilities in a fully featured compact device tailored for flexible working.
Benefits
* High-quality printing at an impressively fast 40ppm
* Colour touch screen enables easy operation for all levels of user
* Supports Secure PIN printing
* Print from smartphones and tablets with support for AirPrint, Mopria and the Canon PRINT Business app
* Automatic duplex printing reduces waste and consumables overheads
* Quick First-Print cuts waiting time and helps maximise workgroup productivity
* Easily work with documents remotely via the cloud
* Device and Output management capabilities
* Simple to maintain with convenient All-In-One Cartridges
Maximise productivity in the office-
Small enterprise workgroups in search of a big productivity boost will find the MF515x A4 black and white laser Multifunctional printer with fax an unbeatable choice. It boasts the powerful features and capabilities of a large office Multifunctional printer but in a compact device that’s easy to accommodate in small spaces. Busy teams will appreciate its fast, high-quality printing and copying at impressive speeds of up to 40ppm. The colour touch screen enables easy operation for all levels of user; while a 600-page paper capacity and Quick First-Print from start-up help your teams work more efficiently. Sensitive documents are protected using the Secure Print function that PIN-protects documents when printing from a PC or mobile device.
Enhanced document sharing-
Busy teams can gain welcome flexibility thanks to the MF515x’s MF Scan Utility (for PCs/laptops) and Canon PRINT Business app (for mobile devices) that enables seamless cloud integration. Teams can use their favourite cloud storage services – like Google Drive and DropBox – to capture, digitise and share documents at any time and from any place.
Smart networking capabilities-
With a host of flexible networking capabilities, the MF515x makes a perfect addition to your enterprise network. Alongside WiFi and Ethernet connectivity, full support for PCL5e/6 and Adobe PostScript printer languages enable easy integration into your Multifunctional printer fleet. Managed print services teams will find the remote service capabilities and support for Canon’s uniFLOW output system make for hassle-free management.
Affordable, sustainable ownership-
When you depend on your Multifunctional printer for consistent quality and reliability, the MF515x won’t let you down, because Canon’s All-In-One Cartridge design replaces all key components at once. Energy consumption and consumables costs are minimised thanks to low energy consumption in Sleep and Standby modes, automatic duplex printing, and a smart power-saving Auto Off feature.
Canon i-SENSYS MF515x - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
100000 pages
Recommended Monthly Volume
1000 - 5000 pages
Max Copying Speed
Up to 40 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 40 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Original Size
128 x 139.7 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, heavy-weight paper, postcards
Standard Media Capacity
600 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to Cloud, scan to FTP, scan to PC
AC 230 V (50/60Hz)
45.3 cm x 47.7 cm x 50.3 cm
24.3 kg
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon i-SENSYS MF515x...
