Canon i-SENSYS MF525x Mono Laser Multifunction Printer
£591.31
13 in stock
Delivery:
Standard: 1-3 working days
  • Type: Fax / copier / printer / scanner
  • Functionality: Copier, Fax, Printer, Scanner
  • Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
  • Stock Status: In Stock
Product codes
The i-SENSYS MF520 series are black and white multi-function, high-volume printers. They are aimed at small businesses and teams in larger enterprises requiring high-quality, fast printing with mobile connectivity.
  • Save time with fast print speeds of up to 43ppm
  • Increase productivity with double sided, single pass scanning
  • High quality 1200 x 1200 dpi print resolution
  • Easy operation with large colour touch screen
  • Improved flexibility with varied media support; A4, A5, A6
  • Increase control with the Universal Login Manager
  • Enhanced security & accounting with uniFLOW
  • Easy mobile integration with QR code & NFC function
  • Improve quality & reliability with Canon Genuine all-in-one cartridges
  • Customise your workflow with the Application Library
Product Description Canon i-SENSYS MF525x - multifunction printer - B/W
Device Type Multifunction printer
Fax Type Super G3 - plain paper
Printing Technology Laser (monochrome)
Monthly Duty Cycle (max) 150000 pages
Recommended Monthly Volume 2000 - 7500 pages
Max Copying Speed Up to 43 ppm
Max Copying Resolution Up to 600 x 600 dpi
Max Printing Speed Up to 43 ppm
Max Printing Resolution Up to 1200 x 1200 dpi
Max Fax Transmission Speed 33.6 Kbps
Fax Resolutions 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning 600 x 600 dpi
Original Size 105 x 128 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type Sheets
Document Feeder Capacity 50 sheets
Media Size 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, postcards
Standard Media Capacity 650 sheets
Bypass Feeder Capacity 100 sheets
Output Trays Capacity 250 sheets
Automatic Duplexing Yes (copying) Yes (printing) Yes (scanning)
Connection Availability Yes
Interface USB 2.0, Gigabit LAN, Wi-Fi(n), NFC
AirPrint Enabled Yes
Office Machine Features Scan to e-mail, scan to Cloud, scan to FTP, scan to PC, scan to USB host, iFAX
Power AC 230 V (50/60Hz)
Dimensions (WxDxH) 49.4 cm x 46.4 cm x 45.2 cm
Weight 20 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon i-SENSYS MF525x...
£591.31
