Enjoy this versatile and efficient multifunction color laser printer, with a color touchscreen and mobile compatibility. The perfect partner for small businesses, seeking a high-performing, but compact solution.
Product Description | Canon i-SENSYS MF631Cn - multifunction printer - colour | Device Type | Multifunction printer | Printing Technology | Laser (colour) | Monthly Duty Cycle (max) | 30000 pages | Recommended Monthly Volume | 250 - 2500 pages | Max Copying Speed | Up to 18 ppm (mono) / up to 18 ppm (colour) | Max Copying Resolution | Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour) | Max Printing Speed | Up to 18 ppm (mono) / up to 18 ppm (colour) | Max Printing Resolution | Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour) | Scanning | 600 x 600 dpi | Display | 5" | Original Type | Sheets | Media Size | 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max) | Media Type | Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, glossy paper, postcards | Standard Media Capacity | 150 sheets | Bypass Feeder Capacity | 1 sheet | Output Trays Capacity | 100 sheets | Connection Availability | Yes | Interface | USB 2.0, Gigabit LAN, USB host | AirPrint Enabled | Yes | Office Machine Features | Print from USB flash drive, scan to e-mail, scan to FTP, scan to PC, scan to USB host | Power | AC 230 V (50/60Hz) | Dimensions (WxDxH) | 45.1 cm x 46 cm x 34.7 cm | Weight | 19.5 kg | Environmental Standards | ENERGY STAR Qualified |
General | |
Printing Technology | Laser - colour |
Display Diagonal Size | 5" |
Colour Support | Colour |
Display Features | Touch screen |
Memory | |
Standard Memory | 1 GB |
Copying | |
Grayscale Half-Tones | 256 |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 999 |
Copying Features | Toner Save, 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy |
Printing | |
Printer Drivers / Emulations | PDF, TIFF, UFRII, JPEG |
First Print Out Time B/W | 12 sec |
First Print Out Time Colour | 10.9 sec |
Scanning | |
Optical Resolution | 600 x 600 dpi |
Interpolated Resolution | 9600 x 9600 dpi |
Colour Depth | 24-bit |
Colour Depth (Internal) | 24-bit |
Document & Media Handling | |
Min Media Size | 76.2 x 127 mm |
Max Media Size | A4/Legal |
Min Media Weight | 52 g/m² |
Max Media Weight | 200 g/m² |
Supported Media Type | Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, glossy paper, postcards |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 76.2 x 127 mm, 215.9 x 355.6 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm) |
Supported Envelope Sizes | International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm) |
Document & Media Handling Details | Paper cassette - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 200 g/m² , Bypass tray - 1 sheet size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 200 g/m² , Output tray - 100 sheets |
Speed Details | Printing: up to 18 ppm (A4) , Copying: up to 18 ppm (A4) |
Connections | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A |
Security Protocols & Features | Secure Print, 802.1x, IP filtering, MAC address filtering |
Operating System Support | Linux, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Windows 8, Windows 8.1, MS Windows Server 2012 R2, Apple Mac OS X 10.7.5 or later, Windows 10, MS Windows Server 2016 |
Software Included | Drivers & Utilities, Presto! PageManager, Canon Print Service Plug-in for Android, iW Management Console, Canon PRINT Business |
Power | |
Voltage Required | AC 230 V (50/60Hz) |
Power Consumption Operational | 850 Watt |
Power Consumption Standby | 13.6 Watt |
Power Consumption Sleep | 0.94 Watt |
Miscellaneous | |
Warm-Up Time | 13 sec |
First Copy Out Time B/W | 12 sec |
First Copy Out Time Colour | 14 sec |
Consumables Included | 1 x Cartridge (black) - up to 1400 pages - Canon 045 Starter , 1 x Cartridge (cyan) - up to 690 pages - Canon 045 Starter , 1 x Cartridge (magenta) - up to 690 pages - Canon 045 Starter , 1 x Cartridge (yellow) - up to 690 pages - Canon 045 Starter |
Compliant Standards | ISO 9296 |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Dimensions & Weight | |
Width | 45.1 cm |
Depth | 46 cm |
Height | 34.7 cm |
Weight | 19.5 kg |
Environmental Parameters | |
Sound Emission | 49 dB (operating) |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 30 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
