Canon imageFormula DR-6030C Document Scanner
£2,512.12
Delivery:
Key features
  • Ultra-compact A3 production scanner
  • High-speed color scanning (60ppm portrait/80ppm landscape)
  • Advanced image processing features
  • Ultra-reliable paper transport system
  • Class-leading energy efficiency
Product codes
Canon's imageFORMULA DR-6030C departmental scanner blends high speeds and reliable document handling with versatility and convenience. The DR-6030C scanner provides comprehensive functionality in a desktop design that effectively delivers document capture benefits in any business application.
Benefits
* Ultra-compact A3 production scanner
* High-speed colour scanning (60ppm portrait / 80ppm landscape)
* Advanced image processing features
* Ultra-reliable paper transport system
* Class-leading energy efficiency
* Optional Flatbed 101 Scanner Unit
* Kofax VRS included
Detailed Features
Take a more detailed look into the Canon imageFORMULA DR-6030C
Exceptional speed and efficiency
Busy working environments will quickly raise their productivity with the DR-6030C’s rapid colour scanning speeds. Canon’s advanced 3-line CMOS CIS sensor technology and JPEG-compression image file transfer process enable colour scanning speeds of up to 80ppm (landscape.)
Compact by design
The DR-6030C is among the most compact A3 production scanners – ideal in corporate office departments or smaller branch offices that have limited desktop space. Scan operators will appreciate its convenient front document feed and exit design for its convenient and comfortable operation.
Excellent performance and superior image quality
The DR-6030C captures precise high-quality images scan after scan. With three dedicated modes designed to enhance text and remove dark or patterned backgrounds, the DR-6030C reproduces clear legible images optimized for OCR applications or for automated data extraction. Additional features like Auto Colour Detection, Auto Size and Deskew Correction, Text Orientation Correction and Customised Colour Dropout further enhance image quality and consistency.
Trouble-free paper handling
Built on the same reliable paper transport system as its market-leading DR-5010C predecessor, the DR-6030C can reliably handle up to 10,000 scans a day. The high-precision roller system allows for jam-free feeding of a wide range of documents: from A3 media and plastic cards to documents up to 3m long. A selectable straight-thru paper path makes it easy to scan items up to 546 g/m² thick.
Leading energy efficiency
The DR-6030C is the most energy-efficient production scanner in its class, using just 46W of power when scanning – saving you money and helping you become more eco-friendly.
Powerful Software
The DR-6030C comes bundled with Canon’s CapturePerfect and CapturePerfect Software Developers Kit (SDK) for easy custom integrations. Kofax VRS – the industry’s leading image processing software – is also included for added image quality assurance.
Flatbed option
For extra versatility, the DR-6030C is fully compatible with the optional Flatbed Unit 101 for scanning bound and fragile documents.
Product Description Canon imageFORMULA DR-6030C - document scanner
Device Type Document scanner - desktop
Interface Type USB 2.0, SCSI
Scan Element Type CMOS / CIS
Light Source RGB LED array
Max Supported Document Size 300 x 432 mm
Input Type Colour
Grayscale / Color Depth (External) 8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 80 ppm (mono) / 80 ppm (colour)
Max Document Size 300 mm x 3000 mm
Automatic Duplexing Yes
Supported Document Type Plain paper
Document Feeder Type Automatic
Document Storage Capacity 100 sheets
Duty Cycle 10000 scans per day
Power AC 230V ( 50/60 Hz )
System Requirements Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows Vista
Microsoft Certification Compatible with Windows 7
Dimensions (WxDxH) 39.8 cm x 31.2 cm x 19.1 cm
Weight 10.5 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon imageFormula DR-...
£2,512.12
