Canon imageFORMULA DR-C230 Document Scanner
£337.84
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Scanning speed of up to 30 ppm/60 ipm (single pass)
  • Versatile feeding of various media including passports, thick ID card
  • Robust & Reliable Design
  • 60 sheet automatic document feeder
  • Ultra-compact
  • Efficient batch scanning with OCR function
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: Legal (216 x 356 mm)
  • Interface: USB 2.0
  • Stock Status: In Stock
Product codes
Designed to provide excellent value and performance to both small and medium sized organizations, the imageFORMULA DR-C230 comes fully equipped with the latest technologies and features required for simple capture and advanced workflows. The device is the latest high-performance desktop workgroup scanner in Canon's award winning series of imageFORMULA document scanners.
The imageFORMULA DR-C230 is based on the successful imageFORMULA DR-C240, providing a compact, robust and reliable device with scanning speeds of 30 ppm/60 ipm. With its robust feeding mechanism the new scanner is capable of handling a variety of different media including scanning 6 mm thick passports through the 60-sheet document feeder. The compact imageFORMULA DR-C230 also includes various advanced image processing features, including text enhancement, automatic deskew and text orientation recognition, to help deliver exceptionally high quality images while saving users valuable time.
Product Description Canon imageFORMULA DR-C230 - document scanner - desktop - USB 2.0
Device Type Document scanner - desktop
Interface Type USB 2.0
Scanning Sensor Type CMOS / CIS
Light Source RGB LED array
Max Supported Document Size Legal (216 x 356 mm)
Input Type Colour
Grayscale / Color Depth 8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 30 ppm (mono) / 30 ppm (colour)
Max Document Size 216 mm x 3000 mm
Automatic Duplexing Yes
Supported Document Type Plain paper, business card, plastic card
Document Feeder Type Automatic
Document Storage Capacity 60 sheets
Duty Cycle 3500 scans per day
Power AC 120/230 V (50/60 Hz)
System Requirements Microsoft Windows 7 SP1, Microsoft Windows Server 2008 R2 SP1, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016, Apple MacOS X 10.10 - 10.12
Dimensions (WxDxH) 29.1 cm x 25.3 cm x 23.1 cm
Weight 2.8 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon imageFORMULA DR-...
£337.84
