Canon imageFORMULA DR-C240 Document Scanner
AFFORDABLE TO RUN AND MAINTAIN!
£491.56
14 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Boost productivity with fast 2-sided scanning at up to 90ipm
  • Easily scan various types of documents including passports with one compact device
  • Enjoy peace of mind with supreme paper-handling reliability and durable construction
  • Enhance your environment with quiet operation, compact build and elegant design
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: Legal (216 x 356 mm)
  • Interface: USB 2.0
  • Compatibility: PC
Product codes
Compact document scanner perfect for busy workgroups and customer-facing environments.
The imageFORMULA DR-C240 is an ultra-compact and powerful desktop scanner featuring a robust design and reliable paper handling for capturing multiple document sizes and formats, including passports.
Main Features
  • Boost productivity with fast 2-sided scanning at up to 90ipm.
  • Easily scan various types of documents including passports with one compact device.
  • Enjoy peace of mind with supreme paper-handling reliability and durable construction.
  • Enhance your environment with quiet operation, compact build and elegant design.
High-performance and flexible applications
The imageFORMULA DR-C240’s premium build quality and productivity-focused features are a breakthrough in this value segment. Offering rapid scanning at up to 45ppm/90ipm, the imageFORMULA DR-C240 is the natural all-round choice for office departments and workgroups. Its quiet operation – and compact, attractive desktop design – make a great impression in front offices and customer service points, for example in banks, hotels, hospitals and government offices.
Designed in response to customers’ needs
The imageFORMULA DR-C240’s robust construction and rugged document feeder were developed as a direct result of customer feedback. It represents a step forward in build quality in this scanner’s segment, effortlessly capturing up to 4,000 scans per day. Your productivity is maximised by the 60-sheet ADF that reliably feeds batches of mixed-sized document and media types: from passports and plastic cards to duplex A4, A3 (using folio) and long documents up to 3m in length.
Precision paper handling
To keep your workflows fluid, the imageFORMULA DR-C240 offers a powerful, high-quality feeding mechanism that ensures best in class reliability for scanning various documents, including ultra-thin papers from 27gsm. The ultrasonic Double Feed Detection and Double Feed Release (DFR) function allow scanning to restart quickly, keeping downtime to a minimum.
Easy operation, consistent results
The imageFORMULA DR-C240 includes a wide range of high quality image processing capabilities. These include automatic page size and text direction detection, text enhancement, a deskew function and automatic colour detection. The user-friendly control panel lets operators scan with a press of a button – accelerating and simplifying scanning tasks.
Affordable to run and maintain
It’s hassle-free to replace the imageFORMULA DR-C240’s long-life retard roller and feed roller unit yourself, which keeps your cost of ownership to a minimum. Impressively low power consumption, at just 19W in operation and 1.4W in standby, further drives down overheads while minimising your environmental impact.
Product Description Canon imageFORMULA DR-C240 - document scanner - desktop - USB 2.0
Device Type Document scanner - desktop
Interface Type USB 2.0
Scan Element Type CMOS / CIS
Light Source RGB LED array
Max Supported Document Size Legal (216 x 356 mm)
Input Type Colour
Grayscale / Color Depth 8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 45 ppm (mono) / 30 ppm (colour)
Max Document Size 216 mm x 3000 mm
Automatic Duplexing Yes
Supported Document Type Plain paper, business card, plastic card
Document Feeder Type Automatic
Document Storage Capacity 60 sheets
Duty Cycle 4000 scans per day
Power AC 120/230 V (50/60 Hz)
System Requirements Microsoft Windows Vista SP2, Microsoft Windows 7 SP1, Microsoft Windows Server 2008 R2 SP1, Windows 8, Microsoft Windows Server 2012 R2, Windows 8.1
Microsoft Certification Compatible with Windows 7
Dimensions (WxDxH) 29.1 cm x 25.3 cm x 23.1 cm
Weight 2.8 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon imageFORMULA DR-...
£491.56
