Canon imageFORMULA DR-M140 Document Scanner
£614.50
Delivery:
Standard: 1-3 working days
Key features
  • Compact, versatile design with selectable paper paths
  • Fast color scanning of up to 80ipm at 300dpi
  • Robust build handles up to 6,000 scans/day
  • High quality image processing features
  • Professional software suite
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: 216 x 3000 mm
  • Interface: USB 2.0
  • Compatibility: PC
Product codes
With a robust, compact design and a U-Turn paper path, the imageFORMULA DR-M140's intelligent features make it a superb productivity booster in busy office departments and workgroups.
Product Description Canon imageFORMULA DR-M140 - document scanner - desktop - USB 2.0
Device Type Document scanner - desktop
Interface Type USB 2.0
Scanning Sensor Type CMOS / CIS
Light Source RGB LED array
Max Supported Document Size 216 x 3000 mm
Input Type Colour
Grayscale / Color Depth (External) 8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 40 ppm (mono) / 40 ppm (colour)
Max Document Size 216 mm x 3000 mm
Automatic Duplexing Yes
Supported Document Type Plain paper
Document Feeder Type Automatic
Document Storage Capacity 50 sheets
Duty Cycle 6000 scans per day
System Requirements Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows Vista
Microsoft Certification Compatible with Windows 7
Dimensions (WxDxH) 31.3 cm x 18.1 cm x 9.3 cm
Weight 2.6 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon imageFORMULA DR-...
£614.50
