Canon imageFORMULA DR-M160II Document Scanner
£686.01
12 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Scans up to 60 pages per minute
  • Single-pass duplex scanning
  • Both sides of a sheet in one pass
  • Up to 60 sheet ADF
  • Usable design
  • Simple hardware and features designed with the user in mind
  • LED control panel
  • One-touch access to pre-configured customizable scan tasks
  • Easy interior access for cleaning and maintenance
  • Reliable feeding
  • Double-feed & non-feed prevention
  • Can handle embossed plastic cards
  • Can handle thick or thin sheets
  • Can handle long or oversized documents
  • High quality scanning
  • Character emphasis improves legibility
  • Shadow cropping
  • Background smoothing
  • Auto resolution setting for scanning mixed batches of text documents and photographs
  • Optical Character Recognition (OCR) to help create searchable and editable information
  • Bundled software solutions
  • Industry standard interfaces for connecting software applications and scanners
  • Eases integration with third-party capture or content management systems
  • Pre-configure repetitive scan jobs
  • One-touch scanning
  • Intuitive user interface
  • Full Auto mode
  • Automatically adjusts multiple settings with a single click
  • Evernote
  • Google Docs
  • PDF/A format output
  • PDF encryption and password protection
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: 216 x 3000 mm
  • Interface: USB 2.0
  • Compatibility: Mac, PC
Product codes
Well suited for workgroups and departments in any industry, the DR-M160II scanner provides the basis for efficient records management and helps reduce paperwork. It delivers capture capabilities that make it an ideal addition, especially in the legal, financial, healthcare, and government sectors.
The strength of the DR-M160II scanner is seen in its throughput, capacity, and overall performance. Scanning up to 60 pages per minute - both sides in a single pass - and holding up to 60 sheets in the ADF, it quickly captures and converts paperbased documents into usable, digital information.
Product Description Canon imageFORMULA DR-M160II - document scanner - desktop - USB 2.0
Device Type Document scanner - desktop
Interface Type USB 2.0
Scan Element Type CMOS / CIS
Light Source RGB LED array
Max Supported Document Size 216 x 3000 mm
Input Type Colour
Grayscale / Color Depth 8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution 600 dpi
Max Document Scan Speed 60 ppm (mono) / 60 ppm (colour)
Max Document Size 216 mm x 3000 mm
Automatic Duplexing Yes
Supported Document Type Plain paper
Document Storage Capacity 60 sheets
Duty Cycle 7000 scans per day
Power AC 120/230 V (50/60 Hz)
System Requirements Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
Dimensions (WxDxH) 28 cm x 17.2 cm x 17.8 cm
Weight 3.2 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon imageFORMULA DR-...
£686.01
