Canon imageFORMULA P-208II Portable Document Scanner
£125.30
11 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Slim, lightweight, and flexible
  • Fits easily into a briefcase or bag
  • Powered via a single USB cable connection
  • Helps reduce cable clutter
  • Immediate scanning without installing drivers or imaging applications
  • CaptureOnTouch software
  • Type: Document scanner
  • Form Factor: Portable
  • Max Paper Size: Legal (216 x 356 mm)
  • Interface: USB 2.0
  • Compatibility: Mac, PC
Product codes
The Canon imageFORMULA P-208II Scan-tini personal document scanner's ultra-compact size and robust features make it ideal for mobile use at home, the office, and virtually anywhere in between. It can be moved from location to location as easily as it moves paper-based information.
The compact and stylish P-208II mobile scanner is the perfect choice for travelling executives and home users. A 10-sheet ADF and high speed duplex scanning ensure productivity is always maintained.
  • Ultra-compact, lightweight and versatile
  • Productive 16ipm double-sided scanning with 10-sheet ADF
  • Supports embossed card and photo scanning
  • Convenient, intuitive plug-and-scan operation
  • Mac and Windows compatible
  • Optional Wi-Fi Unit WU10 available
Highly productive mobile scanning
The tiny P-208II delivers impressive double-sided scanning speeds of up to 16ipm. The integrated 10-sheet ADF enables batch scanning for extra productivity: perfect for scanning contracts and associated documents. You can travel light with the P-208II as it has a footprint that's a little larger than a standard ruler and weighs only 600g. Powered directly via USB, it helps you maintain a high work rate anywhere in the home or on the road.
Plug-and-scan convenience on the go
The stylish, compact and ultra-lightweight P-208II provides true plug-and-scan convenience. With CaptureOnTouch Lite built in, and no additional software or drivers to download, you can simply connect, scan and go. Scanning functions and an improved icon-based user interface mean you will enjoy an even more intuitive scanning experience. An extended choice of plug-ins for SugarSync, OneDrive and Dropbox, alongside Google Drive™, Evernote and SharePoint, make it easy to work with your favourite software tools.
Scan various documents
The P-208II can scan a variety of media, from A4 to irregular-sized documents like embossed card, so it’s perfect for mobile users. Get organised at home and make space by scanning your household bills; or preserve your memories digitally by scanning your old photos in high quality, using a special feature that reproduces images as close to their originals as possible.
Easy-to-use image processing
The P-208II’s range of image processing features includes auto colour detection, text orientation recognition and text enhancement – to deliver high quality images and save valuable time. For convenient and intuitive scanning, use the Full Auto Mode feature that automatically applies the best settings for your document. Simply load up your documents and scan!
Flexible wireless scanning
For the freedom to scan wherever you are, combine the P-208II with the optional WU10 Wi-Fi and battery unit. Use it to wirelessly scan documents directly to your smartphone, tablet or desktop PC, or share the scanner amongst a group of users or devices via a network server or home router.
CaptureOnTouch Mobile
The powerful CaptureOnTouch mobile app gives you the flexibility to scan direct to your iPhone®, iPad® or Android device. Save valuable time with double-sided one-pass document scanning. This free app is available for both iOS and Android devices.
Product Description Canon imageFORMULA P-208II - document scanner - portable - USB 2.0
Device Type Document scanner - portable
Interface Type USB 2.0
Scanning Sensor Type CMOS / CIS
Light Source RGB LED array
Max Supported Document Size Legal (216 x 356 mm)
Grayscale / Color Depth 8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 8 ppm (mono) / 8 ppm (colour)
Max Document Size 216 mm x 356 mm
Automatic Duplexing Yes
Supported Document Type Plain paper, business card
Document Feeder Type Automatic
Document Storage Capacity 10 sheets
Duty Cycle 100 scans per day
System Requirements Apple MacOS, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
Microsoft Certification Compatible with Windows 7
Dimensions (WxDxH) 31.25 cm x 5.65 cm x 4 cm
Weight 600 g
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon imageFORMULA P-2...
£125.30
