Canon imageFORMULA P-215II Document Scanner
DEDICATED ID CARD SCANNER
£252.33
Delivery:
Standard: 1-3 working days
Key features
  • Designed to improve personal productivity and efficiency virtually anywhere
  • Home offices, classrooms, anywhere in between
  • Perfect for stationary users or "road warriors"
  • Portable and mobile
  • Compact and convenient
  • Fits easily into briefcase
  • Built-in card reader and Automatic Document Feeder (ADF)
  • "Plug-and-Scan" capability
  • Immediate scanning without installing drivers or imaging applications
  • Configure routine scan jobs for one-touch access
  • Maximum image quality
  • Includes features to help improve legibility of hard-to-scan documents
  • Trims, straightens, and removes shadows from scanned images
  • Scans mixed batches of documents and photographs
  • Automatically adjusts resolution to improve image quality
  • Productive and flexible
  • Maximum scanning speed via single USB cable connection
  • Integrated card reader
  • Compatible and comprehensive
  • Easy integration with capture and content management systems
  • Scan directly to cloud for improved collaboration and compatibility
  • Multiple file output formats
  • Type: Document scanner
  • Form Factor: Portable
  • Max Paper Size: 216 x 1000 mm
  • Interface: USB 2.0
  • Compatibility: Mac, PC
Product codes
High-speed, mobile document scanner for the office, for home or on the move
The P-215II scanner was designed to improve personal productivity and efficiency anywhere, from home offices, to classrooms, even traveling in between. It can help meet the document capture needs of stationary users and "road warriors" in healthcare, legal services, financial services, and many other areas. Users can conveniently execute general purpose distributed scanning tasks and help reduce paper in the process.
Main Features
  • Speedy USB powered scanning up to 30ipm.
  • Batch scanning with 20-sheet ADF.
  • Ultra compact for space saving and mobility.
  • Supports ID and embossed card scanning.
  • Scan to Google Docs and Evernote.
  • Outstanding image quality.
  • Powerful software supports Mac and PC.
  • Enjoy Wi-Fi scanning with optional WU10.
Most productive USB-powered scanning
The imageFORMULA P-215 is the most productive scanner in its class. With double-sided scanning speeds up to 30ipm and an industry-leading 20-page automatic document feeder users can scan efficiently, in the office, at home or on the move. Full-rated scanning speeds can be powered via just a single USB cable using a USB 3.0 interface.
With a sophisticated smart silver and black design, the ultra-lightweight, compact P-215 is ideal for the office. Its small footprint allows the scanner to fit comfortably on the busy desktops. True plug-and-scan is possible by simply connecting the scanner to any PC or Mac. Canon’s unique built in CaptureOnTouch Lite software is ready to go – there’s no need to load drivers or application software.
Dedicated ID card scanner
With card scanning becoming increasingly important for ID authentication, the P-215 has its own dedicated card scanning slot. A sophisticated switchback feed mechanism ensures it quickly scans ID and embossed cards.
Enhanced image processing
Advanced technology allows for high precision scanning up to 600dpi. A rich range of image processing features, such as auto colour detection, auto text orientation recognition, ensure superb scan quality that is ideal for creating searchable PDFs.
Direct scanning to the cloud
Users have the option to scan direct to various cloud services, including Evernote, GoogleDocs™ and SharePoint. This allows information to be quickly uploaded to the cloud, for anywhere, anytime access.
Powerful software suite
The P-215 uses both ISIS and TWAIN drivers to allow for easy integration with your standard imaging application and includes a full-suite of software applications to help users work more effectively. The intuitive interface of Canon’s CaptureOnTouch software makes scanning easy. It incorporates a Full-Auto Mode function, which automatically applies the best settings to scan jobs. PageManager (Mac) and PaperPort (Windows) provides effective file management and conversion tools. While scanning business cards has never been easier with the BizCard application.
Product Description Canon imageFORMULA P-215II - document scanner - portable - USB 2.0
Device Type Document scanner - portable
Interface Type USB 2.0
Scanning Sensor Type CMOS / CIS
Light Source RGB LED array
Max Supported Document Size 216 x 1000 mm
Input Type Colour
Grayscale / Color Depth 8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 15 ppm (mono) / 10 ppm (colour)
Max Document Size 216 mm x 1000 mm
Automatic Duplexing Yes
Supported Document Type Plain paper, business card, plastic card
Document Feeder Type Manual, automatic
Document Storage Capacity 20 sheets
Duty Cycle 500 scans per day
System Requirements Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X Lion 10.7, Windows 8, Apple MacOS X 10.5 - 10.9
Microsoft Certification Compatible with Windows 7
Dimensions (WxDxH) 28.5 cm x 9.5 cm x 4 cm
Weight 1 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon imageFORMULA P-2...
£252.33
