Canon Legria HF R806 Camcorder Kit inc 32GB SD Card and Case...
Canon Legria HF R806 Camcorder Kit inc 32GB SD Card and Case - Whi
£268.78
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Superb quality
  • Effortless creativity
  • Comfort and ease
  • Rock steady zooming
  • Type: Camcorder
  • Media Type: Flash card
  • Optical Zoom: 32
  • Video Input: Composite video/audio, HDMI, USB 2.0
  • HD Support: 1080p
Product codes
Enjoy superb quality movies that automatically sound as good as they look - even in tricky light - thanks to a host of powerful technologies like DIGIC DV 4. Shoot dramatic-looking movies with slow or fast motion effects, and get creative with touch decoration and cinema-look filters. Capture key moments using advanced Baby Mode. Record comfortably for longer thanks to a lightweight, compact design. Simply point and shoot with easy touchscreen control for great movies. Easily capture steady video footage packed with distant detail thanks to the huge advanced zoom lens with intelligent Image Stabilizer and Zoom Framing Assist.
Product Description Canon LEGRIA HF R806 - camcorder - storage: flash card
Product Type Camcorder - 1080p - widescreen
Media Type Flash card
Memory Card Slot SD card
Image Processor DIGIC DV 4
Sensor Resolution 3.28 MP
Effective Sensor Resolution Video: 2.07 MP - Photo: 2.07 MP
Max Video Resolution 1920 x 1080
Lens System Zoom lens - 32x zoom - 2.8 - 89.6 mm - f/1.8-4.5
Focus Adjustment Automatic, manual
Min Focus Distance 1 cm
Digital Zoom 1140x
Image Stabiliser Optical (Intelligent IS with Advanced Dynamic Mode)
Display LCD display - 3"
Supported Battery 1 x Canon BP-727 Li-ion rechargeable battery (included)
Interface Composite video/audio, HDMI, USB 2.0
Colour White
Dimensions (WxDxH) 5.3 cm x 11.6 cm x 5.8 cm
Weight 235 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon Legria HF R806 C...
£268.78
