The Maxify GX5050 A4 inkjet colour printer is ideal for businesses which required a high volume printing. With functionality of Hi-Speed USB, Wi-Fi, Ethernet, Print and Cloud. This printer has refillable ink tanks (CYMK), up to 14,000 sheets printed in standard mode or up to 6,000 if printing in monochrome. For higher print yield switch to Economy mode for greater savings. Speeds of up to 24 ipm in black and 15.5 ipm in colour. With 2 paper cassettes providing up to 350 sheets (plain paper). Can print banners up to 1.2m length. Print resolution up to 600 x 1200 dpi. Controlled via an LCD 2-line screen.
Product Description | Canon MAXIFY GX5050 - printer - colour - ink-jet | Printer Type | Workgroup printer - ink-jet - colour | Weight | 9 kg | Inkjet Technology | Canon FINE (Full-lithography inkjet Nozzle Engineering) | Refillable Tank | Yes | Ink Refill System | Ink Tank System (ITS) | Ink Palette Supported (Colours) | 4-ink - cyan, magenta, yellow, black | Media Size Class | A4/Legal | Max Media Size | 216 x 1200 mm | Min Media Size (Custom) | 89 mm x 127 mm | Max Media Size (Custom) | 216 mm x 1200 mm | Print Speed | Up to 24 ipm - B/W , Up to 15.5 ipm - colour | Max Resolution (B&W) | 600 x 1200 dpi | Max Resolution (Colour) | 600 x 1200 dpi | Automatic Duplexing | Yes | Interface | USB 2.0, LAN, Wi-Fi(n) | Intelligent Assistant | Google Assistant, Alexa | AirPrint Enabled | Yes | Media Type | Envelopes, plain paper, iron-on transfers, photo paper, magnetic photo paper, glossy paper, matte paper, semi-gloss paper, restickable photo paper | Total Media Capacity | 350 sheets | Media Handling | 250-sheet paper cassette, 100-sheet input tray | Monthly Duty Cycle (max) | 45000 pages | Networking | Print server | Printer Features | Wireless Direct Print | Power | AC 100-240 V | System Requirements | Android, Microsoft Windows 7 SP1, Microsoft Windows Server 2008 R2 SP1, Google Chrome OS, Apple iOS, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple iPadOS, Microsoft Windows Server 2022, Windows 11, Apple macOS 11.x, Apple macOS 10.13.6 - 10.15, Apple macOS 12.x | Dimensions (WxDxH) | 39.9 cm x 41.6 cm x 23.8 cm |
General | |
Printer | |
Ink Cartridge Configuration | 4 individual ink tanks |
Built-in Devices | 2 line monochrome LCD display |
Connectivity Technology | Wireless |
First Print Out Time B/W | 7 sec |
First Print Out Time Colour | 8 sec |
Media Handling | |
Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 101.6 x 152.4 mm, 89 x 127 mm, 216 x 1200 mm, 127 x 127 mm, 127 x 177.8 mm, 200 x 250 mm, 203.2 x 254 mm, 180 x 250 mm, 177.8 x 254 mm |
Envelope Sizes | International DL (110 x 220 mm), Com-10 (105 x 241 mm) |
Media Weight | 64 g/m² - 275 g/m² |
Media Feeders | Input tray: 1 - 100 sheets - 216 x 1200 mm weight: 64 g/m² - 275 g/m² , Paper cassette: 1 - 250 sheets - 216 x 297 mm weight: 64 g/m² - 105 g/m² |
Duty Cycle | |
Networking | |
Security Protocols & Features | WPA-PSK, TLS, 802.1x, WPA2-PSK, TKIP, AES, PEAP |
Expansion / Connectivity | |
Connections | 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 |
Miscellaneous | |
Features | PIXMA Cloud Link |
Power | |
Power Device | Power supply |
Voltage Required | AC 100-240 V |
Frequency Required | 50/60 Hz |
Power Consumption Operational | 20 Watt |
Power Consumption Stand by | 1.4 Watt |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Software / System Requirements | |
Software Included | Drivers & Utilities, PosterArtist Lite, Canon Easy-PhotoPrint Editor, Canon IJ Printer Assistant Tool |
OS Required | Android, Microsoft Windows 7 SP1, Microsoft Windows Server 2008 R2 SP1, Google Chrome OS, Apple iOS, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple iPadOS, Microsoft Windows Server 2022, Windows 11, Apple macOS 11.x, Apple macOS 10.13.6 - 10.15, Apple macOS 12.x |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Sound Emission (Operating) | 49 dBA |
Dimensions & Weight | |
Width | 39.9 cm |
Depth | 41.6 cm |
Height | 23.8 cm |
Weight | 9 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
