Canon MAXIFY MB2755 InkJet Multifunction Printer
£117.19
Delivery:
Key features
  • Fast and productive
  • Wi-Fi connectivity
Product codes
All-In-One colour inkjet for home offices. The Canon MAXIFY MB2755 provides mobile printing and cloud integration, while its 500-sheet paper capacity and fast 24 images per minute (ipm) mono print speed maximise productivity.
For home offices that demand productivity:
A fully featured printer, scanner, copier and fax designed for home offices. With a large 500-sheet paper cassette and 50-sheet automatic document feeder, the Canon MAXIFY MB2755 produces outstanding prints with deep, dense blacks, vivid colours and crisp text using its marker- and friction-resistant DRHD inks. This quality doesn't come at the expense of speed: print A4 at an ultra-fast 24 ipm in mono and 15.5 ipm in colour, while first page out time (FPOT) is just 6 seconds.
Keep running costs to a minimum:
From low energy consumption of just 0.2 kWh (TEC) to the individually replaceable colour cartridges, economy is a priority. Black cartridges provide an ISO yield of 1,200 pages and colour cartridges 900 pages. The optional 4-colour multipack contains a full set of replacement inks for even better value.
Designed for productivity:
Double-sided printing and support for a variety of paper sizes and types, from A4 plain paper to labels, envelopes, photo paper and even two-sided ID card copying makes light work of common office print jobs. Printing, copying, scanning or faxing is just a few taps away, with a highly responsive 7.5 cm (3") TFT colour touchscreen and improved interface.
Mobile-ready, cloud-ready, work-ready:
Support for Google Cloud Print, Apple AirPrint (iOS), Mopria and the Canon PRINT app provide quick and simple printing and scanning from mobile devices. You can print from the cloud and scan and save documents to cloud services. Supported services include Google Drive, Dropbox, Evernote, OneNote, OneDrive and Concur. Built in Access Point mode means that smart device users can connect to the printer without a Wi-Fi network.
Comprehensive monitoring and maintenance capability:
IP address filtering enables restricted access options, giving permission to only a select number of users, while SMTP email support allows secure scan-to-email. A range of further options allow system administrators to quickly and easily configure the printer and restrict certain operations, such as scan-to-USB.
Network integration:
IT managers and system administrators will appreciate the Canon MAXIFY MB2755s' Simple Network Management Protocol (SNMP) compatibility, making device management and integration into existing office networks easy. SNMP enables a range of maintenance monitoring functions, including ink levels, error status, and page counts.
This model has replaced the MAXIFY MB2350
Product Description Canon MAXIFY MB2755 - multifunction printer - colour
Device Type Multifunction printer
Fax Type Super G3 - plain paper
Printing Technology Ink-jet (colour)
Inkjet Technology Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Monthly Duty Cycle (max) 15000 pages
Recommended Monthly Volume 200 - 1000 pages
Max Copying Speed Up to 22 ppm (mono) / up to 11.5 ppm (colour)
Max Printing Speed Up to 24 ipm (mono) / up to 15.5 ipm (colour)
Max Printing Resolution Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
Max Fax Transmission Speed 33.6 Kbps
Fax Resolutions 300 x 300 dpi, 200 x 200 dpi
Scanning 1200 x 1200 dpi
Display 3"
Original Size A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type Sheets
Document Feeder Capacity 50 sheets
Media Size 89 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Plain paper, photo paper, glossy paper, matte paper, high resolution paper, luster paper, semi-gloss paper
Standard Media Capacity 500 sheets
Automatic Duplexing Yes (printing)
Connection Availability Yes
Interface USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled Yes
Office Machine Features Save to USB flash drive, scan to e-mail, scan to network, scan to Cloud, MAXIFY Cloud Link, Mobile Printing, access point mode
Power AC 120/230 V (50/60Hz)
Dimensions (WxDxH) 46.3 cm x 38.9 cm x 32 cm
Weight 12.1 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon MAXIFY MB2755 In...
£117.19
