Canon MAXIFY MB5155 A4 InkJet Multifunction Printer
£167.84
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Fast productivity
  • Wireless printing for smartphones and tablets
  • Cloud connectivity - scan to cloud or email
  • Large sheet capacity
  • Type: Fax / copier / printer / scanner
  • Functionality: Copier, Fax, Printer, Scanner
  • Output Type: Colour
  • Wireless Capability: Wired
  • Technology: Ink-jet
Product codes
A heavy-duty multifunction colour inkjet printer, scanner, copier and fax, with support for mobile devices and cloud services, fast 24 images per minute (ipm) mono print speed and easy network integration.
Small office, huge productivity:
A fully featured printer, scanner, copier and fax designed for smaller offices that still need great mono and colour print quality while being economical to run. Marker- and friction-resistant DRHD Pigment inks produce strong blacks, deep colours and crisp text. The Canon MAXIFY MB5155 prints A4 at an ultra-fast 24 ipm in mono and 15.5 ipm in colour, plus a first page out time (FPOT) is just 6 seconds, while single pass two-sided scanning means you can scan faster than ever.
Superb print economy:
From its low energy consumption of just 0.2kWh (TEC) to the individually replaceable colour cartridges, economy is a priority. Black cartridges provide an ISO yield of 2,500 pages and colour cartridges 1,500 pages, letting your office work with fewer interruptions. The optional 4-colour multipack offers even more cost-effective printing.
Increased productivity and ease of use:
Printing, copying, scanning or faxing is simple, with the Canon MAXIFY MB5155s' large 8.8 cm (3.5") TFT colour touchscreen and improved user interface. In addition to its high-capacity 250-sheet feeder and 50-sheet automatic document feeder, the printer's double-sided printing and support for a variety of paper sizes and types - from A4 plain paper, to labels, envelopes, photo paper and even two-sided ID card copying - make light work of common office print jobs.
Mobile-ready, cloud-ready, work-ready:
Support for Google Cloud Print, Apple AirPrint (iOS), Mopria and the Canon PRINT app provide quick and simple printing and scanning from mobile devices. You can print from the cloud and even scan and save documents to popular cloud services, including Google Drive, Dropbox, Evernote, OneNote, OneDrive and Concur. Access Point mode means mobile device users can connect to the printer without a Wi-Fi network.
Comprehensive monitoring and maintenance capabilities:
IP address filtering means only a select number of users can be given access, while SMTP email support allows secure scan-to-email. System administrators can quickly and easily configure the printer and restrict certain operations, such as scan-to-USB.
Effortless network integration:
Simple Network Management Protocol (SNMP) compatibility makes it easy to integrate the printer into an existing office network. The SNMP standard enables a range of maintenance monitoring functions, including ink levels, error status, and page count.
This model has replaced the MAXIFY MB5050
Product Description Canon MAXIFY MB5155 - multifunction printer - colour
Device Type Multifunction printer
Fax Type Super G3 - plain paper
Printing Technology Ink-jet (colour)
Inkjet Technology Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Monthly Duty Cycle (max) 30000 pages
Recommended Monthly Volume 250 - 1500 pages
Max Copying Speed Up to 22 ppm (mono) / up to 11.5 ppm (colour)
Max Printing Speed Up to 24 ipm (mono) / up to 15.5 ipm (colour)
Max Printing Resolution Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
Max Fax Transmission Speed 33.6 Kbps
Fax Resolutions 300 x 300 dpi, 200 x 200 dpi
Scanning 1200 x 1200 dpi
Display 3.5"
Original Size A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type Sheets
Document Feeder Capacity 50 sheets
Media Size 89 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Envelopes, plain paper, photo paper, glossy paper, matte paper, high resolution paper, luster paper, semi-gloss paper
Standard Media Capacity 250 sheets
Automatic Duplexing Yes (copying) Yes (printing) Yes (scanning)
Connection Availability Yes
Interface USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled Yes
Office Machine Features Save to USB flash drive, scan to e-mail, scan to network, scan to Cloud, MAXIFY Cloud Link, access point mode
Power AC 120/230 V (50/60Hz)
Dimensions (WxDxH) 46.3 cm x 39.4 cm x 29.1 cm
Weight 11.4 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon MAXIFY MB5155 A4...
£167.84
