Canon MAXIFY MB5455 A4 InkJet Multifunction Printer
£199.71
Delivery:
Key features
  • Quality prints
  • Easy to use
  • Low running costs
  • Wi-Fi connectivity
Product codes
For efficient small office printing, without compromising on performance, quality or reliability MAXIFY MB5455 is your ideal choice. With high quality, marker resistant inks, Wi-Fi and Ethernet connectivity and single pass two-sided scanning, you can print at high volumes, faster than ever before.
Rapid Print & Scan:
Quick First Print enables very fast First Print Out Time (FPOT), approx 6 seconds mono. You can also quickly scan both sides of a document using single pass 2 sided automatic document feeder (ADF).
High quality prints, every time:
Dual Resistant High Density ink has been especially developed for business printing. This high quality ink gives you vivid colours, deep blacks and crisp text, without the worry of smudging.
Easy to use, easy to be productive:
A large 8.8cm colour touchscreen provides easy access to all of MAXIFY MB5455 functions. In addition to a high-capacity 500 sheet feeder, 50 sheet automatic document feeder and double-sided printing, MAXIFY MB5455 also supports a variety of paper sizes and types - from A4 plain paper, to labels, envelopes, photo paper and even two-sided ID card copying - taking the stress out of common office print jobs.
Low running costs:
With MAXIFY MB5455, you can achieve superior printing quality, that doesn't cost the earth to run. With low power consumption combined with ink yields providing 2,500 mono pages and 1,500 colour pages, there are now longer stretches between having to replace cartridges.
Simple to manage and maintain:
Simple Network Management Protocol (SNMP) allows you to integrate your printer into your work place, making it easy to run as part of a busy office environment. MAXIFY MB5455 does this by giving you the ability to track records of use, ink levels, error status and page counts of all the printers in your network. In addition to this you can also filter by IP addresses to restrict printing access and provide secure scan-to-email.
This model has replaced the MAXIFY MB5350
Product Description Canon MAXIFY MB5455 - multifunction printer - colour
Device Type Multifunction printer
Fax Type Super G3 - plain paper
Printing Technology Ink-jet (colour)
Inkjet Technology Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Monthly Duty Cycle (max) 30000 pages
Recommended Monthly Volume 250 - 1500 pages
Max Copying Speed Up to 22 ppm (mono) / up to 11.5 ppm (colour)
Max Printing Speed Up to 24 ipm (mono) / up to 15.5 ipm (colour)
Max Printing Resolution Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
Max Fax Transmission Speed 33.6 Kbps
Fax Resolutions 300 x 300 dpi, 200 x 200 dpi
Scanning 1200 x 1200 dpi
Display 3.5"
Original Size A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type Sheets
Document Feeder Capacity 50 sheets
Media Size 89 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Envelopes, plain paper, photo paper, glossy paper, matte paper, high resolution paper, luster paper, semi-gloss paper
Standard Media Capacity 500 sheets
Automatic Duplexing Yes (copying) Yes (printing) Yes (scanning)
Connection Availability Yes
Interface USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled Yes
Office Machine Features Save to USB flash drive, scan to e-mail, scan to network, scan to Cloud, MAXIFY Cloud Link, access point mode
Power AC 120/230 V (50/60Hz)
Dimensions (WxDxH) 46.3 cm x 39.4 cm x 35.1 cm
Weight 12.9 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Canon MAXIFY MB5455 A4...
£199.71
