The perfect everyday All-In-One for printing, scanning and copying. From text-heavy documents to family photos, the compact Canon PIXMA MG2550S’s print engine is built for quality and ease-of-use.
Print, scan, copy – home printing made easy:
The ideal home All-In-One, letting you print, scan and copy documents and photos at speed without compromising on quality. Simple to use, the Canon PIXMA MG2550S is a stylish, compact and desk-friendly device with powerful features for every home user.
Affordable device, premium print quality:
The Canon PIXMA MG2550S offers incredible value for money: an affordable home printer that produces superior quality documents and photos. FINE Cartridge technology means deep blacks, vivid colours and a stunning level of detail.
Up to 30% lower cost per page:
Using the optional high-capacity Canon XL ink cartridges, you can save as much as 30% on the cost per page compared to their standard equivalents. Get more pages per cartridge and go longer between cartridge replacements; the Canon PIXMA MG2550S won’t cost the earth to run.
Be creative:
Easily organise and print your photos with the face-recognition features of My Image Garden app, while CREATIVE PARK PREMIUM opens a world of creative possibilities with its selection of designs from professional artists, all available for you to use as postcards, calendars, birthday cards and much more.
Energy saving built-in:
Use less energy with Auto Power On/Off. Hit print on your laptop and watch as the printer immediately emerges from its power-saving mode, ready to print without even switching it on.
This model has replaced the PIXMA MG2450
Product Description | Canon PIXMA MG2550S - multifunction printer - colour | Device Type | Multifunction printer | Printing Technology | Ink-jet (colour) | Inkjet Technology | Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink | Max Copying Speed | 1.6 ppm (colour) | Max Printing Speed | Up to 8 ipm (mono) / up to 4 ipm (colour) | Max Printing Resolution | 4800 x 600 dpi (colour) | Scanning | 600 x 1200 dpi | Original Size | 216 x 297 mm (max) | Original Type | Sheets | Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) (max) | Media Type | Envelopes, plain paper, photo paper, glossy photo paper | Standard Media Capacity | 60 sheets | Connection Availability | Yes | Interface | USB 2.0 | Power | AC 120/230 V (50/60Hz) | Dimensions (WxDxH) | 42.6 cm x 30.6 cm x 14.5 cm | Weight | 3.5 kg |
General | |
Printing Technology | Ink-jet - colour |
Copying | |
Maximum Copies | 21 |
Printing | |
Inkjet Technology | Canon FINE (Full-lithography inkjet Nozzle Engineering) |
Ink Cartridge Configuration | 1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow) |
Ink Palette Supported (Colours) | Cyan, magenta, yellow, pigment black |
Colour | 4-ink |
Scanning | |
Scan Element | CIS |
Optical Resolution | 600 x 1200 dpi |
Grayscale Depth | 8-bit |
Colour Depth | 24-bit |
Colour Depth (Internal) | 48-bit |
Document & Media Handling | |
Max Original Size | 216 x 297 mm |
Max Media Size | A4/Legal |
Min Media Weight | 64 g/m² |
Max Media Weight | 275 g/m² |
Supported Media Type | Envelopes, plain paper, photo paper, glossy photo paper |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm |
Supported Envelope Sizes | International DL (110 x 220 mm), Com-10 (105 x 241 mm) |
Document & Media Handling Details | Input tray - 60 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 275 g/m² |
Speed Details | Printing: up to 8 ipm (A4) - B/W , Printing: up to 4 ipm (A4) - colour , Scanning: 14 sec (A4) , Copying: up to 1.6 ipm - colour |
Connections | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type B |
Operating System Support | MS Windows 7, MS Windows XP SP3, MS Windows Vista SP2, MS Windows 7 SP1, Windows 8, Windows 8.1, Windows 10, Apple Mac OS X 10.7.5 - 10.11 |
Software Included | Drivers & Utilities, Canon Easy-WebPrint EX, Canon Full HD Movie Print, Canon My Image Garden, Quick Menu, MP Driver including Scanning Utility |
Power | |
Voltage Required | AC 120/230 V (50/60Hz) |
Power Consumption Operational | 9 Watt |
Power Consumption Standby | 1 Watt |
Miscellaneous | |
First Copy Out Time Colour | 31 sec |
Dimensions & Weight | |
Width | 42.6 cm |
Depth | 30.6 cm |
Height | 14.5 cm |
Weight | 3.5 kg |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
