Take your business on the road. Light and portable with versatile wireless connectivity and smartphone control, get effortless and professional results wherever your work takes you.
Product Description | Canon PIXMA TR150 - printer - colour - ink-jet | Printer Type | Photo printer - ink-jet - colour | Form Factor | Portable | Weight | 2.1 kg | Inkjet Technology | Canon FINE (Full-lithography inkjet Nozzle Engineering) | Ink Palette Supported (Colours) | 5-ink - cyan, magenta, yellow, black, pigment black | Media Size Class | A4/Legal | Max Media Size | 215.9 x 676 mm | Min Media Size (Custom) | 55 mm x 89 mm | Max Media Size (Custom) | 215.9 mm x 676 mm | Print Speed | Up to 9 ipm - B/W , Up to 5.5 ipm - colour | Max Resolution (Colour) | 4800 x 1200 dpi | Interface | USB 2.0, Wi-Fi(n) | Intelligent Assistant | Google Assistant, Alexa | AirPrint Enabled | Yes | Media Type | Envelopes, plain paper, photo paper, photo stickers, magnetic photo paper, glossy paper, matte paper | Total Media Capacity | 50 sheets | Media Handling | 50-sheet input tray | Networking | Print server | Printer Features | Borderless printing | Power | AC 120/230 V | System Requirements | Android, Microsoft Windows 7 SP1, Microsoft Windows Server 2008 R2 SP1, Apple iOS, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016, Windows 10 Mobile, Apple MacOS X 10.11.6, Microsoft Windows Server 2019, Apple macOS 10.12 - 10.15 | Dimensions (WxDxH) | 32.2 cm x 18.5 cm x 6.6 cm | Manufacturer Warranty | 2-year Limited Warranty |
General | |
Printer | |
Ink Type | Canon ChromaLife100 |
Built-in Devices | 1.44 inch (3.6 cm) monochrome OLED display |
Connectivity Technology | Wireless |
Direct Printing Specifications | PictBridge |
Media Handling | |
Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 55 x 91 mm, 101.6 x 152.4 mm, 127 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm, 215.9 x 676 mm, 55 x 89 mm, 89 x 89 mm, 177.8 x 254 mm |
Borderless Photo Sizes | ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 101.6 x 152.4 mm, 88.9 x 88.9 mm, 127 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm, 177.8 x 254 mm |
Envelope Sizes | International DL (110 x 220 mm), Com-10 (105 x 241 mm) |
Media Weight | 64 g/m² - 275 g/m² |
Media Feeders | Input tray: 1 - 50 sheets - 215.9 x 676 mm weight: 64 g/m² - 275 g/m² |
Networking | |
Security Protocols & Features | WEP, WPA-PSK, WPA2-PSK |
Expansion / Connectivity | |
Connections | 1 x USB 2.0 - 24 pin USB-C |
Miscellaneous | |
Cables Included | 1 x USB-C cable |
Consumables Included | 1 x ink tank (pigmented black) - Canon PGI-35 , 1 x ink tank (yellow/cyan/magenta/black) - Canon CLI-36 , 1 x printhead |
Features | PIXMA Cloud Link |
Power | |
Power Device | Power adapter |
Voltage Required | AC 120/230 V |
Frequency Required | 50/60 Hz |
Power Consumption Operational | 8 Watt |
Power Consumption Stand by | 1.7 Watt |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Compatible Services | IFTTT |
Software / System Requirements | |
Software Included | Drivers & Utilities, Canon Easy-PhotoPrint Editor, Canon IJ Printer Assistant Tool |
OS Required | Android, Microsoft Windows 7 SP1, Microsoft Windows Server 2008 R2 SP1, Apple iOS, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016, Windows 10 Mobile, Apple MacOS X 10.11.6, Microsoft Windows Server 2019, Apple macOS 10.12 - 10.15 |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Sound Emission (Operating) | 40.5 dBA |
Dimensions & Weight | |
Width | 32.2 cm |
Depth | 18.5 cm |
Height | 6.6 cm |
Weight | 2.1 kg |
Manufacturer Warrranty | |
Service & Support | 2-year Limited Warranty |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
